Look at my post in the resources section... more specifically move the handle (with the fabric still in it!) out of the way. Ive no wish to lose the fabric up inside the trim!
The fabric is permanently attached to the aluminium bar (handle) follow my guide above and you'll get a very satisfying fix .... more specifically move the handle (with the fabric still in it!) out of the way. Ive no wish to lose the fabric up inside the trim!
Corrected? Agreed!Here is the original post for those without VIP status (anyone without with VIP status, you should get it to support the forum)
We had an issue with the blind open our sliding door. The little black retainer clip thing on the end of the strip at the bottom came off inside the runner. VW dealer master tech took seconds to retrieve the black end bit and fix it back.Hi - we experienced exactly the same issue - the whole thing was swapped over under warranty by Listers VW Worcs - in my view the blind is vulnerable to a bit of accidental abuse as it is over the door. I have instructed the family not to pull it down unless the sliding door is closed.
