martinbagnall.home
We picked up our GC680 at the end of last year and sine then it has been in the VW workshop 3 times to try to fix repeated errors (they have changed a junction box and performed a software update) but still occuring.
The only modification we made after delivery (before the errors occurred) was installing a Scorpion Tracker S5+ with immobiliser.
The errors do not occur when the engine is cold at the start of the day, often if we stop for coffee / lunch and stop for an hour or two the engine will attempt to start, you can just hear it try to turn over (similar to a low battery with insufficient charge) then we will get the following errors:
1 - Drive System visit workshop - Amber
2 - ACC - Amber
3 - either Start / Stop or Travel Assist is currently unavailable - Amber
It will start if the then hold the Start / Stop button down and the codes clear.
It is due to go back to VW for a 4th time (under warranty) but interested to hear if anyone else has seen similar faults or thoughts on potential cause by the tracker with the immobiliser.
2 - ACC - Amber
