Gazbibelots1860
Hi, I’ve searched the forum but can’t quite find the answer to this. We have just got to France and there is no water coming from the tap it splitters a dribble comes out and the pump activates. And I’ve noticed there is water seeping from the base of the wardrobe, underneath the wardrobe/fridge. It’s not from the window drainage holes, there also doesn’t seem to be water leaking from any pipes connected to the tap under the sink. No water coming from hoses at tank refil or where blue hose leaves the fresh water tank
Any ideas? I can drain the water tank and just not use the tap whilst on holiday but be good to know if it’s a tricky or easy fix (I fear it’s a tricky one as I can’t see leakage anywhere easy to access
