Fuses photo.
P
Phil Dub
Aldershot
Grand California 600
Can somebody with a Grand California 600 take a photo of the fuses under the dashboard and the fuses under the seat . I think my fuses are not in the correct slots and I would like to make a comparison
Thank you .
Thank you .
The fuse position will vary from vehicle to vehicle. The only thing you can be assured of is that the fuse will be in the correct fusebox and be the correct value.
If you want the correct fuse map for your vehicle then your Dealership can get it from the VW Erwin system using your VIN.
As said already fuses will be fitted according to the specifics of your vehicle and the dealers will be able to advise based on the build documentation if there is something amiss. If you would rather do your own checks you Erwin yourself, https://volkswagen.erwin-store.com/erwin/showHome.do. It's paywalled at around £8/hr and a bit of a convoluted beast to use but contains everything you will ever need to know about your GC, full workshop & repair manuals specific to your VIN. As per your request I've attached a couple of photos I took while doing some work on my van a while back, a MY22 GC600. Ive fitted a Wolfbox rear view mirror and dash camera hence the picture of the fuse array under the drivers dash is marked up and has some additional wiring but under the near side seat is as factory.IMG_2114.jpegView attachment IMG_1543.jpeg
