What’s draining my batteries?
But you have the fridge on. The fridge could be using amps fulfilled by the solar input, so 0amps from the battery.
Question doesn’t the battery 70% look suspect if the fridge on and potentially its demand met by the panels when 13.3 on control panel or 13.4 volts at mppt panel
The 70% is misleading. Apparently the VW controller doesn’t know I’ve got solar so the percentage goes down as normal even though the batteries are getting topped up. Once I turn the ignition on it resets to 100%
8 days since the original post!!!
