Flappy flaps today!!
CaliGem
CaliGem
Cheshire
T5.1 se 180
Morning all....
... Nothing to do with the hot weather... Well maybe but the flaps just are not behaving today!
This beaut starting wildly waving at every vehicle I passed today. It seems the clip isn't clipping anymore! No idea how to control my flap anymore! Any suggestions welcome.
Morning all....
I’ve never had this problem, but it does always feel likely.
Other than replacement, my mind goes to a small Velcro patch on the underside (that itself will eventually have to be replaced).
Its always felt a bit flimsy, with you on that. Looks like heat and vibration (roads near me are a MESS) so it didn't stand a chance it seems!
I had the same issue earlier this year. I fitted this. Very straightforward - just take a picture of the wiring before disconnecting for peace of mind
Xtremeauto 240V Mains Flush Fit Socket Box - Caravan 16 Amp Socket, Mains 16amp Campervan Inlet Hookup Cable Socket Plug, Flush To Fit Most Caravans & Campervans External 16a Sockets (Black) https://amzn.eu/d/09jwz6JH
Thanks all. I'll get my flappers under control again in no time and let you know which method I go for!
I had the same... and another vote for small amount of magnetic strips, been fine every since
I had this problem recently, and fixed it using these self adhesive magnets:
https://www.amazon.de/-/en/dp/B0CCTXGRFG?tag=unique0ed-21
The trick to getting them in the right position is to remove the bit of paper covering the adhesive side, and put the magnets on the little screw heads on the EHU fitting. Then simply close the flap, push hard, and the magnets will end up being attached to the flap in exactly the right places!
