SusiBus
2-pedal power Peppa Pig trike
I'm finding our O6S bellows fold in much more effectively than any previous ones, but they still leaked in heavy rain!
Don't rely on bellows bungee to stop the sides inflating outward in a breeze - the elastic along the centre of its its length is way too weak to exerpt any meaningful restraining power.
When the same thing happened after I hadn't been paying enough attention thinking the bungee was going to do what it claimed, what I did was sew a loop of thread to the inside of the fabric at the point where the two reinforcing strips kink and just before lowering the roof I connect the two using an offcut from the end of bellows bungee with a plastic hook on each end.
Stretched between the two loops the elastic has just sufficient tension to ensure the strips always start folding inwards, and by the time the roof is half way down its done its job and has gone slack.
All that's needed next time I put the roof up is remember to check if one or other hook already freed itself - sometimes one end will unhook itself once the roof is fully down - and if not just hop up and disconnect it.
One great way to nacker your roof is storing stuff up there.Don't rely on bellows bungee to stop the sides inflating outward in a breeze - the elastic along the centre of its its length is way too weak to exerpt any meaningful restraining power.
Thanks for the information, it's very useful to know about a solution. I have reluctantly learned to live with it but will never be happy. Thanks again.Hi Glenn, sorry to hear of your roof problems. My 2 year old T6.1 has had similar issues with the roof not seating fully following repeated lopsided events with the hydraulics. Bristol were not interested and claimed it was operator error despite me providing photo and video evidence of the roof trying to close at alarming angles. VW customer care suggested a second opinion and Breeze in Poole eventually sorted the problem for us but only after they had replaced front and rear scissors. This was completed under warranty but involved a lot of visits and hassle we could have done without. I’m not sure how bad yours is and whether you have learned to live with it, but replacement scissors maybe the answer
If snagging the roof buckled the plastic strip and can't be straightened, without a some method of encouragement it has in my unexpert experience a tendency thereafter to fold outwards.One great way to nacker your roof is storing stuff up there.
You say “I hadn't been paying enough attention thinking the bungee was going to do what it claimed.” What happens next time you’re not paying attention and forget to attach the silly bit of elastic? This is one of the daftest ideas I’ve read on this forum ever. You half lower the roof and then clamber inside? Or do you use a Victorian child chimney sweep?
Paying attention has meant in 17 years this has never happened to me. No elastic required.
