CaliforniaCylus
Leaking 06s bellows are rare.I have an 06s. It leaks!
Got any pictures of it leaking?
What date were your leaking 05S changed to 06S?The O6S bellows have clear tape down the corner seems, which VW have seen fit to add to stop water ingress at this place. Ours also leaked v. badly between the rubber seal at the base and the aluminium roof in heavy rain. To much tension me thinks. O5S changed to O6S's under warranty.
I have OS4 bellows on a 2024 6.1 Ocean.What date were your leaking 05S changed to 06S?
2nd that about T6 bellows.Correct , normally dry. But in storm force conditions I get leaks. Driving sideways rain for hours and they start to show ingress. I aquatexed them for that reason after reading here it's good stuff, it isn't, it's sh1te
I can fully understand your desire to reject. That is not an acceptable message or position from the Dealer that a California is only for use in dry weather.I just bought a 74 plate California beach 2 weeks ago and went away for the night straight away to get a feel for it. I have previously had two converted VW vans with SCA roofs that never leaked. It rained and I had all the problems discussed in detail in this thread. Dealer took it in straight away to “sort out”. Just had an email to say it is ready. They have not done anything to it but said “advice from VW for all California models is that if it is persistent heavy rain then the roof should be dropped to prevent any water ingress.” I have responded to say it is not fit for purpose if the 2 people sleeping upstairs have to find somewhere else to go if it starts raining in the night. I cannot believe that VW actually sell a campervan that cannot be used in the rain. Thanks to the members who provided contact details for VW exec office I have also spoken with them today - they didn’t like the sound of the don’t use in the rain advice.
Hugely disappointed and I am now trying to reject the vehicle.
I think that would be 04S.I have OS4 bellows on a 2024 6.1 Ocean.
Yes I have but in essence it leaks on the horizontal seam below the front fly mesh.Leaking 06s bellows are rare.
They said my bellows are the latest version. It’s like they refuse to believe that it is possible for yet another version to be leaking. Here’s an idea, they could ask Reims or Westfalia to make a decent set for themI can fully understand your desire to reject. That is not an acceptable message or position from the Dealer that a California is only for use in dry weather.
If you have version an older version than 06S I cannot figure why they wouldn't warranty fix to a version which has obvious improvements to fix leaks.
You could get Kernow Transporters to replace it for about a grand and issue a court claim for the money spent. But it's a lot of aggravation.
I sometimes think the VW warranty isn't worth anything...
Same here. 05S plus Aquatex the seams (especially the vertical ones) solves the leaking2nd that about T6 bellows.
My T6 with the single layer bellows only leaked once in 6 years under relentless wind driven rain on to the side of the van.
For what it’s worth my new T6.1 with 05s bellows leaked at the front corner seams at first decent wetting with wind driven rain.
Aqua texted all seams and no leaks in similar wind driven rain.
Sorry for the delay in replying.What date were your leaking 05S changed to 06S?
Thanks for getting back to me.Sorry for the delay in replying.
They were changed on the 07/10/24. It was when VW didn't seem to be that reluctant to honour a warranty claim for a genuine known fault. This is similar to thier actions with regard to roof corrosion. Once it started to cost them a lot of money, they switched to a cheaper repair that has given owners endless problems.
Hope this helps.
Yes. Supplied to main dealer. Awaiting decision on Warranty.Leaking 06s bellows are rare.
Was curious to see / understand how bad leaks can be on the 06S. When our 03S bellows leaked the water formed puddles in each corner and then cascaded over onto the headlining and seats.Yes. Supplied to main dealer. Awaiting decision on Warranty.
If you have waterproof bellows, don't be tempted to change them.Was curious to see / understand how bad leaks can be on the 06S. When our 03S bellows leaked the water formed puddles in each corner and then cascaded over onto the headlining and seats.
But 06S bellows definitely have major improvements with the black rubber seam sealer strips and also the vertical transparent seaming tape.
There should be a lot less places for them to leak!!!
I'm expecting one day to need to go to 06S but we currently have very waterproof 03S ones.
Our 06s leaks. A lot less than 03 or 04, this was 2.5 hours into some rain in France the other day. Ended up putting the cover on, got soaked. It hasn’t previously, but it did this time. Wrong type of rain for sure.Leaking 06s bellows are rare.
That pic looks reminiscent of my current 04S the one time they leaked - put Aquatex on them and no real trouble since. Had a bit of damp the once since but it was so minor we couldn't be sure if it was a minor leak or condensation. Am sure they will likely leak again at some point as ultimately the wrong amount of rain will ultimately find a way, as without a seam sealer on that lower joint the pooling water will eventually always find some way in. Looking closely at your pic it looks like the water ingress is initially along that upper of the two rows of stitching on the bottom "hinge" of the window flap, which would make sense as that's where the water will collect. VW did supply us with a cover but haven't actually used it yet, after having made a fuss in the first place to make them pay for it.Our 06s leaks. A lot less than 03 or 04, this was 2.5 hours into some rain in France the other day. Ended up putting the cover on, got soaked. It hasn’t previously, but it did this time. Wrong type of rain for sure.
We used 4 tins of spray Aquatex before we left just in case.That pic looks reminiscent of my current 04S the one time they leaked - put Aquatex on them and no real trouble since. Had a bit of damp the once since but it was so minor we couldn't be sure if it was a minor leak or condensation. Am sure they will likely leak again at some point as ultimately the wrong amount of rain will ultimately find a way, as without a seam sealer on that lower joint the pooling water will eventually always find some way in. Looking closely at your pic it looks like the water ingress is initially along that upper of the two rows of stitching on the bottom "hinge" of the window flap, which would make sense as that's where the water will collect. VW did supply us with a cover but haven't actually used it yet, after having made a fuss in the first place to make them pay for it.
Had two sets of 03S before the current 04S and they leaked almost as badly as if we had just left the window open !
Tricky decision on whether you ask VW to replace them again and maybe end up with a worse job or whether you try Aquatex. Personally I would put Aquatex on it as that will stem the vast majority of the flow, and most likely stop it all together - and its completely invisible (strong odour during application but completely disappears once dry)
What’s your technique of application please?Old thread resurrected, but if I had any doubts over the effectiveness of Aquatex to cure our bellows leak, then they are no more.
We had biblical rain one night last week in Germany with reasonably strong and shifting winds and not a single leak.
At one point the rain was hitting the front face of the bellows quite strongly and nothing was getting through the zip and seam areas that were previously problematic.
Aquatex may not have worked for a few who tried it, but it certainly did for us.
Also gets my vote. 05 bellows leaked at seams in both front corners and front zip out panel.What’s your technique of application please?
Sorry but I think that the dealer is being reasonable - having previously had leaks I’m suprised you’ve waited 2 years to test a repair.Hi all, We have a '23 Cali which had leaking 02s bellows, the dealer changed for 03s under warranty in 2024, and we only used the van since in sunny spells, I tested them with a spay and found leaks, and now VW and the EO are refusing replacement stating that warranty replaced parts only have a 2 year guarantee and were outside that, so no liability.
Any experiences here or advice on taking the case to the motor ombudsman?
Thanks.
