DGB99
I have a 2023 Ocean with 300W solar installed to charge the leisure batteries and then a power pack via the MPPT load connection.
The system has worked flawlessly, including over a recent 3 week Wild Atlantic Way (when I was of course driving every day).
I am now at Fidden Farm on Mull where I have been parked since Saturday. Solar has been keeping the leisure batteries at close to 100% each day but after 3 days the tap stopped working on my return from a walk. I assumed this was a blown fuse but checked all 5A fuses under the passenger seat, no issues.
I then noticed that the fridge had turned off; I switched it back on but it went off again after a few seconds. I also could not start the heater.
My Ocean has a full electric door which I have used quite a bit as I have a dog. I then noticed the engine battery was low (11.? V) so started the engine. After 2/3 minutes I turned it off. The tap, fridge and heater immediately worked and have done so until this evening when I had to idle the engine for another couple of minutes. All well again.
I understand that the door use is discharging the engine battery but why does this impact on the tap, fridge and heater which are powered by the leisure batteries which are close to 100% (currently 12.70V). What am I missing?
