RockinNRollin
Where to next?
This post is about the auxiliary heater (“heat continuously”) on a T6.1 although it might be the same unit as earlier generations. Specifically it’s about turning off the heater(!).
Normal behaviour; after being on for some time; turning off causes the fan speed to increase for a short while (sometimes), but always to then run at a low fan speed for a few minutes which I assume is to cool off the innards of the heater after the flame has been extinguished.
At the weekend, having used the heater normally for the last few evenings, the behaviour was quite different when I turned it off. The fan speed went very high (like when you first turn the heating on and it’s pumping on air) but then abruptly stopped after about 5 seconds. Then there was a small wisp of smoke trickling out of the vent and a slight smell (difficult to be sure as the campsite had a lot of BBQs and fire pits going!). The next day I tried several separate heating cycles and all behaved normally. The first cycle there was a very slight burnt smell to the first air out of the vent then all was fine. On all subsequent occasions the heater shut down normally, with the fan whirring for a few minutes after deactivating the heating.
Has anyone experienced this? My guess is a glitch in the system causing the fan to cut off prematurely?
