L
LandT
Hi
As a retried electrical engineer, thought I'd take the time to try and understand the California's electrical systems.
I found some of the posts were sometimes misleading, probably applying to older California's?
I did some electrical tests around our (24 plate) T 6.1 ocean, as well as downloading a 2,000 page set of VW wiring diagrams.
I have drawn up a Wiring Overview (attached below) and would welcome comments.
Here are a few measured observations
Tim
- The engine battery is charged when connected to EHU (external power through A11 onboard charger)
- Almost all the leisure electrical equipment is controlled by the "computer" J608 special control unit / E153 (unlike older models)
- The inverter is a full sine wave 300W (450W peak) according to VW SSP 705
- I attach a screen shot of the leisure battery voltage during a short trip. It shows that the relay between the leisure batteries & engine battery can open and close while driving. It also shows that the leisure batteries can be a part of the engine's smart alternator system by providing current to reduce fuel consumption. This needs to be overridden (max power on the control panel) on the way to a camping trip to make sure the leisure batteries are fully charged.
- All the 12v sockets in the cab & rear are powered by the leisure batteries (but not the 2x USB C outlets beside the gear lever)
- The water pump and fridge are powered & controlled from J608 (Special Control Unit) not via separate fuses as in older Californias.
Tim
