Fridge on a New California Beach Camper T7
Jotoncius
Spain
Hi,
I just received my New California Beach Camper.
I’d like to have a Fridge for food and drinks.
With the new configuration, I’m not sure what would be the better setup and dimensions for that.
Any suggestions o where to place and recommended dimensions?
Thanks!
Just check the dometic (fridges and other appliances) site. Dometic is the producer of the VW Ocean 2025 fridge.
Hi,
Than
Hi, where did you end up putting the fridge?
I have the same question. checking dimensions I cannot find any nice fridge and space combination. the front seats are 255mm apart and so can only get a 12L between them, at bit and behind the driver or passanger seat they will need to be moved some where each time.
I am considering getting a 25L Dometic, putting it behind the passander seat and placing it on the passanger seats when in sleep mode. a bit fiddly but i dont see another option.
I ended up buying a drawer fridge which fits below the bed shelf. Dometic only do a 20l drawer fridge and it’s a chunk of money.
I’m picking up the beach in a weeks time so will take some pics and send them over.
Nice find.
Just ordered that fridge.
Just found a nice pre built indium grey beach at the German port from Breeze. Order is in.
If you use only two rear seats, you can use the Dometic CFX2 37L. It fits perfectly in the middle and is the exact height needed to serve as a base for the bed.
Very expensive thou !
I have a beach with two rear seats only. I really wanted to buy the new Cfx5, they are vacuum isolated and should be very efficient. But even the smallest one is too big for me.
I considered following placement options:
1. Between front seats.
Obvious spot but only 245mm wide. And I enjoy walking to the back too much to give it up.
2. In the trunk:
I hate opening the trunk doors. Too heavy and never able to close them on the first try. Need to slam them hard. Fridge would not be easily accessible.
3. Instead of the third seat, under the bed.
Reasonable choice. You have 425mm height available. Dometic would fit here. I might go for this option if I feel the need for a larger fridge. But the space is precious and I first want to try a smaller one:
4. Behind the rear seats but before the trunk (technical box) starts.
Max 280mm high to fit under the folded rear seats under the bed.
I figured out, that this is the only storage space that is comfortably reachable from the cabin. If you move the rear seats about 25-30cm forward, the living space is still large enough. You have at your disposal storage of this size: 125*25cm. Best utilized, when you stack two 25cm high boxes on each other. Because 28-25cm box fits under the folded seat under the bed. I searched fridges, that are close to this 23*~50*28cm optimal size.
I ended up purchasing this one: https://www.amazon.es/dp/B0B8W9WHBX?tag=unique0601-21
True size after removing handles is: 433*322*280mm. It's very quiet and it can fit 1.5l waterbottle or wine bottles. That is all I need. It consumes around 20w when running. I think this tiny one will be enough.
But the 32cm width is a bit too much. So I ended up to recess it about 5cm into the trunk on the right side of the vehicle, where there is free space (not the tech box). Will post a photo soon.
Now I'm on the hunt for other boxes that will fit that space behind the seats.
Optimal size:
Lower: 2pcs 24*40*29
upper: 2pcs 22*40*28 or 23*40*26
And this is, what it looks like. Behind the seats (next to the fridge) there is still 25x80cm space for storage. Max height 25-28cm stacked in two levels, so that it fits BELOW folded seats. There is still 14cm below or above the fridge (to bed height, 425mm) which I'll use for something. You might as well use a larger fridge, but I don't need one.
The plastic box is IKEA SAMLA 65l that fits perfectly instead of the third seat
We use an Alpicool G22 on a pull out tray in the boot - as part of an extended rear kitchen. It just fits under the table holding features in the boot when on the sliding tray (it's tight on a tray - would be a centimetre clear on the boot floor). I guess you could pull it forward into cabin also with the seat pulled forward. It's pretty cheap. https://amzn.eu/d/02djss85
Presumably consumes more power so might depend if that's important.
The clearance under the table is 351mm and your fridge has 335. So it's a tight 16mm space. I'm surprised that the tray is this thin. I didn't plan to install a tray because it takes some space. but if it's just few mm, I might reconsider it.
Good choice if you don't mind having the fridge in the boot. As I said, I hate opening the heavy tailgate....
I suspect alpicool is about the same as dometic - both well insulated compressor fridges
There's plenty clearance with no tray.
With a tray it's tight for sure. I use this slider: https://www.gruenthal-mobilcamping.de/produkt/heckauszug-vw-t7-new-california-beach-camper-1000mm/
If you place the fridge away from the table holding features at the side, you have plenty clearance to the table itself, when stowed (i.e in the middle). Even if you do run the fridge through the supports around the edge holding the table, it slides through. There is a central support near the seat though that offers gentle interference in my case (At 1000mm long that tray does go into cabin slightly where it is). It scuffs the fridge there if you do that. Even then, there is a bit of give to let it through. Maybe some slight variability by vehicle? But you can make it work for sure.
I imagine spacetray will be similar.
I'm considering a fridge that has a height of 449mm for our new T7 Beach;
Can anyone tell me if the height 449mm will be just too tall to fit under the bed in the middle seat position please? Don't want it to make the bed a bit lumpy or not sit flat..
If so I guess the Dometic CFX2 37 or CFX5 35 would still be a better bet as being about 30mm lower might mean we could pull it out easier with the bed in situ if needed.
But look at the power consumption when cooling 4.5 Ah.
That’s why you pay the extra for Waeco and Dometic.
449, will not fit under the bed. I measured only 407mm of free space.
I think it depends on the model, from a quick Google they seem to be comparible unless I've missed something
I have run portable fridges for many years, in a variety of off road vehicles, around the world and Dometic, Waeco, Engel, National Luna all perform at nearer to 1Ah.
Fridge compressor technology has dropped in price massively but I strongly advise you look very carefully at the typical power consumption, my experience is you will quickly regret buying a cheaper fridge that you then have to invest to keep it running off grid.
I have run portable fridges for many years, in a variety of off road vehicles, around the world and Dometic, Waeco, Indel, National Luna all perform at nearer to 1Ah.
What’s your go to fridge then ?
I didn't buy dometic, because none fitted the size that I wanted. I purchased this cheap one not because I wanted to save money, but because the size is perfect for me (fits under the folded rear seats under the bed.).
And I'll tell you, it's great. Consumption is very good, quote quiet. I'm glad I didn't pay multiples for dometic as I can't imagine that it could be much better than this one.... https://www.amazon.es/-/en/gp/aw/d/B0B8W9WHBX?tag=unique0601-21
Things have changed, years ago it was about build quality and robustness these days weight makes a huge difference and whilst compressor fridges are quite expensive they were far more expensive comparatively.
The most efficient fridges used to be the Engel ones running Sawafuji swing motors. I had a 40l one that would use 0.6 Ah which meant on old AGM batteries I could get three days.
Things are different now as you can add capacity with lithium and solar to run full time.
But either way if you want an off grid fridge setup you will be balancing battery capacity / compressor efficiency or add the ability to top up the battery with solar.
I run my fridge in the T7 full time on level 4 all year with no issues even on cloudy days.
