Accessories For Sale Yakima Whispbar Roof bars, £120
Ch1pbutty
Ch1pbutty
Burgess Hill
T5 Cali on order
No wind noise.
Lockable
T-track slot on top for roof boxes etc.
Width allows for skinny roof box + SUP/ surfboards stack at same time.
Once footpack is installed, no tools are required to fix the bars as uses a thumb screw, then locking cover goes on over the top.
Work very well with solar panels as the footbase stays in situ when bars are removed (see last photo) , so very quick to install/ remove.
Where about are you. Had these on an old car and really liked them
They are great, would keep them but now have a high top, so boards now go on the side.
We are located in Burgess Hill, West Sussex.
Pretty far away, I'm in Edinburgh. Don't suppose you'd be able to post?
Hi, they are 160cms long when packed so works out very expensive. Once you go over 150cm the rates shoot up.
Happy to pack them up if you can find / arrange a cheaper courier
Hi.
Have just seen you have these for sale
What did box did you use with these?
Having seen yours, I've just been on roof box company to research then a bit more.
Noticed that they state they don't fit all roof boxes. Didn't want to put an offer on them if I'll struggle to get a box for them.
Hi.
We had a Kamei husky roof box & also fitted the in-laws Thule box with no issues; Sometimes you need to purchase a T-track fitting fit if they are not supplied with the roof box.
See below for example, slides into channel on the top of the roof bars. Thread then goes up into roof box & then secured with hand tightened nut (no need for spanner)
(Fyg - issues tend to be with the older traditional clamp fittings - ‘U scaffold clamp’ due the the width of the bar as the clamp is not wide enough to slot under the roof bars, although most more modern boxes now have a different clamp - ratchet crab claw -design to allow for wider aero bars).
