2022 Beach 6.1 Dead Battery and no charge
Millymilomoo1
wrexham
T6.1 Beach camper 150
re written.....
Vehicle: California Beach 6.1 (2022), under 10,000 miles.
The battery was found to be discharged and has been replaced; however, the replacement battery is not holding charge.
Battery test results: OK
Cranking test results: OK
Charging system test: Not OK (no charge output detected)
There is currently no evidence of the charging system supplying any charge to the battery. could this be an alternator issue
Not much of what you’ve typed makes sense. Go back and work out what your problem is and what test you actually performed.
no need to be so sassy
If you mean you’ve tested the voltage at the battery with the engine running and it’s less than 13.4. V then, yes it would suggest your alternator is shagged.
Have you test for fault codes?
re written.....
I do not have a beach but most likely a fuse between alternator and battery ?
are you talking about household battery or starter battery ?
Check fuse in left most position on top of battery.
Picture is ocean but I guess it is the same in beach
