Fuse box help
joeb1230
2016 California Ocean 204
Caterham
T6 Ocean 204
Hi
Can anyone help? I am trying to get the rear blower to work on my 2016 Cali. I have checked Loz's fuse diagram on this site and believe the fuse location to be bottom right underneath the 20 and 30A fuses already in situ. I have tried to install a 30A fuse as per the diagram but fuse will not go in. I have taken a picture of the location and it seems that the left side of the fuse holder is blocked.
Does anyone know if this is normal and I need to look elsewhere for the fuse location or is there a remnant of an old fuse in there?
Hi
Excuse me for asking, but why do you think the rear blower is not working because a fuse is missing?
Be aware, with VW Transporters/Californias the Fuse value and Fuse Box are accurate BUT the fuse position can vary from vehicle to vehicle.
At the risk of asking the bleedin obvious, have you checked it all against the wiring diagram and confirmed everything is as it should be……..? I think I know the answer…..
Thank you. Which wiring diagram are you referring to?
