Vasari
Hello everyone,
I’ve searched the forum but couldn’t find the exact same symptoms. I’m really hoping someone here has experienced something similar or can point me in the right direction. I’m having several electrical issues with my 2008 Volkswagen T5 California, and I’m struggling to figure out where the problem might be.
Main problems:
What happens with the fridge:
When I turn on the fridge, the fan runs, the compressor seems to be working, and the fridge does cool. However, after a while the snowflake icon starts blinking, and the fridge stops.
When I try to start the parking heater:
Battery status:
Checks already done:
OBD fault codes:
If anyone has experienced something similar or has ideas about where I should start checking (relay, battery charger, wiring, control unit, etc.), I would really appreciate your help.
Thanks in advance!
Main problems:
- Rear leisure battery is not charging
- Control console shows error code 3100
- Fridge stops after a while
- Parking heater does not start
- The interior lights start flickering
- The control console shows Voltage Plausibility Fault
- When measuring directly at the battery, the voltage drops to about 12.25 V
- However, the control console shows around 13 V, which seems unrealistic because the engine is not running
Battery status:
- Both batteries are relatively new
- The voltage shown is about 12.4 V
- I checked all fuses under the driver’s seat – all of them are good, although I can see some have been replaced before
- The parking heater works perfectly when the van is connected to external 220 V power
OBD fault codes:
- 00668 – Vehicle electrical voltage terminal 30 – Lower limit not reached
- 00991 – Interior lights – Electrical error in circuit
Thanks in advance!
Heating works perfectly
