600 fridge
Al Cali
Al Cali
Poole
Grand California 600
Had our grand 600 for a few weeks and getting used to it . The fridge is the worst thing ever just makes everything super cold drains the battery and makes everything wet apart from that it’s great .
Not had this problem, you do need to play with the setting to get used to it, no issue with moisture here.
Hi
The fridge settings , a series of lights, is also the light for the fridge.
As such if you set the fridge on setting 2 ( 2 lights on) then after a few seconds all 5 lights are on. And every time you open the door all 5 lights are on. This is because at that point the fridge setting is no longer displayed - it’s just acting as a light. So there is no visual reminder what setting is selected.
We have found setting 2 good.
Initially when on a higher setting we had things freeze in the tray below the freezer section and condensation. We ran a fridge thermostat- to be sure we got it where we needed, setting 2. When you check yourcurrent setting - let us know what you found it to be set on and if a lower setting works for you.
Good luck
Thankyou , this forum is fantastic. Have put on 2 will report back !
Check the tray directly under the freezer is pushed fully in. Things tend to freeze independent of settings if its incorrectly fitted.
Very important, the temperature sensor is located above the sliding tray (which separates the refrigerator compartment from the freezer compartment at the top). If the tray isn't pushed fully back into place, it disrupts the proper division between the fridge and freezer sections. As a result, the control system detects the warmer air from the refrigerator area and mistakenly interprets the entire space as needing more cooling — causing the compressor/motor to run continuously (as if the whole unit were a freezer).
