Solar panels from Solar Camper Solutions
Not if you have LED lights
No LED lights, just the poverty spec' candles :rolleyes:
I will need to look at my solar and other charging options, but probably not until I change the SCA roof for a high top..........
In the meantime, will drive around with headlights on (using power) in order to get the alternator to generate power :thumb
I have just plugged a USB charger into a 12v accessory port wired into the load port on a victron MPPT and to my surprise it lit up despite being dark outside. I can only assume that this power is coming from the leisure batteries and not off loading any extra power once batteries are full as I originally assumed?
Is this normal behaviour or is there a setting that needs changing?
Normal behaviour. The Victron runs a default algorythm controlling the load terminals, that default is set to protect the leisure batteries, and try and make sure they get a full charge at least once a day. It'll switch off the load terminals if it feels it can't achieve those goals, and turn it back on when it can.
Load isn't just for excess power.
From the manual:
3.8.3. BatteryLifeWhen the solar charger is not able to recharge the battery to its full capacity within one day, the result is often that the battery willcontinually be cycled between a ‘partially charged’ state and the ‘end of discharge’ state. This mode of operation (no regular fullrecharge) will destroy a lead-acid battery within weeks or months.The BatteryLife algorithm will monitor the state of charge of the battery and, if needed, day by day slightly increase the loaddisconnect level (i.e. disconnect the load earlier) until the harvested solar energy is sufficient to recharge the battery to nearly thefull 100%. From that point onward, the load disconnect level will be modulated so that a nearly 100% recharge is achieved aboutonce every week.
Victron manual said:
The available operation modes are:
  • BatteryLife (default setting):
    This algorithm is self-adapting and aims to maximise the battery's lifespan. For a detailed explanation of its functionality, please refer to the BatteryLife chapter for a description of its functionality.
  • Conventional algorithm 1:
    12V system: OFF when Vbatt < 11.1V, ON when Vbatt > 13.1V.
    24V system: OFF when Vbatt < 22.2V, ON when Vbatt > 26.2V.
    48V system: OFF when Vbatt < 44.4V, ON when Vbatt > 52.4V.
  • Conventional algorithm 2:
    12V system: OFF when Vbatt < 11.8V, ON when Vbatt > 14.0V.
    24V system: OFF when Vbatt < 23.6V, ON when Vbatt > 28.0V.
    48V system: OFF when Vbatt < 47.4V, ON when Vbatt > 56.0V.
  • Always off:
    The load output is always OFF.
  • Always on:
    The load output is always ON.
  • User defined algorithm 1:
    OFF when Vbatt < Vlow.
    ON when Vbatt > Vhigh.
  • User defined algorithm 2:
    OFF when Vbatt < Vlow or Vbatt > Vhigh.
    ON when Vbatt is between Vlow and Vhigh.
  • Automatic Energy Selector (AES):
    ON when Vbat > Vhigh.
    OFF when Vbat < Vhigh for the pre-selected AES time.
    OFF when Vbat < Vlow.
Link
Just to say a big thank you to Roger for his help today. Currently way in the Alps. Victron app said there was a firmware update, so I installed it. Solar stopped working instantly! Bought my kit from Roger 3 years ago, but thought I would email him to see if he could help. A couple of emails later and all good. Outstanding customer service, thank you.
What was the solution?
We don't all want to be ringing up Roger :)
It's an overkill for most people :) but I put the option up there as I do sell the odd one. Mostly for people who camp over winter.
I have three panels on my T7, I run the fridge full time on level 5 and it takes about two hours of bulk load via the Victron MPPT to recover the batteries. I recommend the Victron because their app lets you see what’s going on.
I’ve had all the lights on for hours, charged a couple of iPhones, watched a movie on the projector powered from the USBC and the parking heater on for 30 minutes and managed to get the batteries down to 50% overnight.
With the three panels you know that by the next evening even on a dull day you will be fully charged to go again. I suspect I would have been fine with two but a bit like range anxiety three suits me.
Hi, I understand that you are one of the few who already has a solar system on the new T7.
I purchased a Victron 100/30 and a 300W solar panel. I wanted to ask you if you could tell me where it is best to connect the negative terminal (black cable) of the MPPT, directly to the battery or to the frame? Would you be able to share a photo of the black cable wiring?
Thanks in advance.
Thanks in advance.
The -tve output from the MPPT controller should be connected to the Chassis via a Chassis earth point or bolt otherwise you bypass the battery monitoring system and will get abnormal readings on the Control Panel.
Rololux
dspuk
dspuk
Dazza-doo
7K
Arie
Brownbetty
14K
paulo12
paulo12
