Heat Immediately/Heat Continuously - Finally it makes sense!
Ok, software just flashed to the Norwegian version. Just the heater bit, nothing for the motor. It's clearly different and have the Water Heater option showing in the roof control. All tested and working.
Thanks @sidepod for digging into this. It's a lot better now!
Dongle back in the post for the next recipient.
Well that could be me. Heard it is on its way today .
It’s much better isn’t it. It feels like it’s set up how it was designed as opposed to a daft work around that makes little sense. Glad you’re happy.
Just to confirm that I had this modification done last night and all seems well; took about 25 minutes. Thanks to all!
Happy with it? I think I’m next with the dongle
I think old Fite is snowed under! He asked me not to pass on his number anymore.
If anyone else is looking to get this done let Fite know. I did mine last night so Dingle currently in uk.
I think I've answered my own question... it does work on T6 too.
But essentially I need to buy this kit
and then get the guy mentioned on this thread to do the coding or follow the coding in this video....
Is that right? Sorry if I'm being thick.
In this video Eugene connects the signal wire to the connector block underneath the seat. If a T6 has the factory fitted Eberspacher air heater, this green/white wire is not present in pin 1, so a wire will need to be installed from the Webasto coolant heater to underneath your seat.
That sounds easier said than done... I don't understand why VW haven't included this by default on all vans. Anything to save 10p.
On my Beach, I bought the kit from eBay (Lithuania) and flashed the software myself with VCP. As I was having a new radio fitted by Dav-Tec in Chesterfield,I paid him to install the receiver, and also to do the wiring. A vehicle lift makes the job a bit easier. Advanced In-Car Technologies in Poole also do this mod, but it's not cheap.
