Under hob cupboard light won’t go off!
  • Thread starter MauriceG’Rage
  • Start date
MauriceG’Rage
Norfolk
T6.1 Ocean 204 4 motion
I’ve just spent an am and a leg on an Ocean . . . Everything seems to work ok - apart from the light in the cupboard under the sink/hob won’t go off! I can’t find a switch! The only clue I have is the left hand sliding door also doesn’t catch closed, which sort of indicates something’s missing?
Light switch is a pushbutton on the wnd of the unit next to the mains socket. Two buttons, one for the led strip round the front of the kitchen and one for inside the cupboard.
Thank you. I’ve now found it!
Was having the same problem tonight, now sorted. Historical stuff on this forum is so good
Anyone got a photo of this light? Perhaps something I could retrofit in my t5.1?
I just used a battery powered motion sensor light. 2xAA batteries lasted over a year with frequent use.
If you put a coat or any other item of clothing on the back of the passenger seat it can knock the switch especially if someone pushes the seat right back. took me a while to figure that one out..
Somebody better post a photo of this feature
