New Model 680
W
Wondering Star
Cambridgeshire
T6 Beach 150
Hi
Not been on the California scene for the last 5 yrs as our present van is a Hymer Grand Canyon S.
Thinking of changing but now require a longer van with AWD that must be winterized to cope with minus temperatures.
We off grid whenever possible and presently run a Lithium system with solar, from memory this was a weakness in the original Van?
Does anyone know if this has been addressed, we would require a minimum of 300 ah (lithium) plus a large inverter etc.
Insulation is also a must, by that I don't just mean heated water tanks but a properly lined van, our next stage of campervaning will involve extensive touring of Scandinavia.
Many thx
So you have a number of options:
Hymer Grand Canyon S 700
Adria Supertwin 700 SGX
MEGAMOBIL Re-Aktiv 700 Max
RP Rebellion
And others
I am looking for a similar van at the moment
Yes, plan to view at the NEC next month, 700s Cross trail looks interesting but not that keen on the interior materials.
Wood effect looks naff and carpet type material on the walls looks like a Thor cost cutting measure compared to my present vehicle.
To be honest I think the 680 interior is far more practical.
Another one to add to the list is the Malibu Genius, although I suspect the bathroom may be the compromise as we do want a useable shower area.
New 680 still has AGM batteries. This is by far the VW weakness, as we know from having a 2021 680.
Yes you can upgrade to Lithium; however, not with VW. We have a GC680 and we have upgraded the battery and charger. Our new lithium battery has been located in one of the rear cupboards and the new charger is in the cupboard next door that houses all the other electric/solar controls. This upgrade has been a game changer in terms of off grid camping. We used Off Grid Power Solutions, Wantage, Oxford. Nigel and his Father were brilliant, very knowledgeable and reasonably priced - Highly recommended.
175 amp with a 50amp charger. No issue in fitting a larger capacity lithium battery if required. I may do this in the future if I feel necessary?
That's good to know, presently I'm running with 200ah which has been adequate but would like a little more to run a microwave/ coffee machine.
200aH should be plenty, certainly for a coffee machine. Microwave maybe a little different.
I had 150ah lithium in my BoxDrive600XL and was sufficient for 2-3days offgrid with compressor fridge & Nespresso machine run 3-4x per day.
Salut
Nous n'avons pas été sur la scène californienne ces 5 dernières années car notre fourgon actuel est un Hymer Grand Canyon S.
Je songe à changer de véhicule, mais j'ai maintenant besoin d'un fourgon plus long, à quatre roues motrices, qui doit être adapté aux températures négatives pour l'hiver.
Nous sommes autonomes en énergie autant que possible et utilisons actuellement un système au lithium avec panneaux solaires ; de mémoire, c'était un point faible du van d'origine ?
Quelqu'un sait-il si ce problème a déjà été résolu ? Nous aurions besoin d'une batterie d'au moins 300 Ah (lithium) ainsi que d'un gros onduleur, etc.
L'isolation est également indispensable, et je ne parle pas seulement de réservoirs d'eau chaude, mais aussi d'un fourgon correctement isolé. Notre prochaine étape en camping-car consistera en un long voyage à travers la Scandinavie.
Merci beaucoup
cs reismobile son les meilleur
We've got a Fogstar 628ah in our GC600, we were off grid for a week at Le Mans last year and with help from the Solar topping up we never went below 70% -
Fitted by RV Installations along with an uprated 90amp/hr split charge..
