Replacing Starter Battery
Calibrator
Hi, have just replaced the starter battery in my 2014 SE 140 Bluemotion with a
A6 Varta Dynamic AGM 110 Car Battery 12V 80Ah (580901080)​
I am inputting battery details with Carista.
Questions:
1) Carista doesn't recognise Varta as a manufacturer, is this a problem?
2) Is the number above in brackets the battery serial number? Carista prompt says S/N should be 10 digits/letters whereas number above is only 9.
Many thanks
Questions:
Many thanks
It doesn't matter what number you use as long as it is different to the previous number . All it is doing is telling the Computer that you have a new battery and to calculate a new charging profile.
When you change Auxiliary Batteries, you need to change also this number ?
You do NOT need to do any coding when changing the Leisure Batteries.
