Solar panel advice
Dukeylabdog#1
Dukeylabdog#1
Newport
T6 Coast 102
Hi l'm after a bit of advice, regarding my Glass Solar panel. I've had a an issue with the solar contoller, which l've now changed. I've also checked to see if power is coming from the panel to the controller, which indicates there is (not sure on the amps through). However on checking the panel itself, l've noticed there's water underneath a plastic film..
Can you remove this plastic film or will removing it destory the solar panel.
Also can this film be replaced
Many thanks for any advice
How old is the Panel?
Glass? It looks more like one of the aluminium backed plastic panels………. ?
I've cleaned and polished the solar panel. See the attached photo. It seems to be pulling anything between 2v to 9v depending on sun and daylight. However it doesn't seem to be charging the leisure battery!!!
Yup, the output voltage on your panel is way too low to charge you battery. I recently replaced mine with a CIGS panel instead of the traditional flexible glass panels. The CIGS are much more resilient to point damage and are truly flexible. I’m no longer scared of the car wash .
The W per m2 is slightly lower, but the trade-off in robustness is worth it imo.
Oh, and the least fun part of replacing the panel was definitely scraping off the sikaflex it had been liberally installed with by the previous owner. I went through some 50 plastic scraping razors and a few decent sized blisters on my hands!
ewen.a
ThomasHJ
ThomasHJ
11K
themagician
themagician
Gelato
15K
California_Ocean
California_Ocean
OllieCollieCali
Californication69
Californication69
secret lemonade drinker
