Solar Advice - New owner
Rosie75
Rosie75
Leicestershire
T6.1 Ocean 204
Hi and looking forward to being part of the group! I have just bought a California Ocean 6.1 2022 which has come fully loaded, however I would like to add a solar panel. Can anyone point me in the right direction, I believe they are self fit onto the roof rails, but would like a supplier people have used and would recommend. Any advice would be appreciated. Thank you
Hi - top right is a search button and you will find a wealth of info, fitting instructions and our prefered supplier.
Roger Donoghue is the owner of Solar Camper Solutions and a Forum Member, well regarded.
Great! I found his email address after I posted this and sent him a message as I understand he can fit them too as well as supply, we pass by on the M5 regularly so would be ideal for us. Thanks for taking the time to reply! Just got to work out how to use all the gadgets now!
Roger fitted my 3 panels - sterling service :)
Roger supplied and fitted my 3 panels. Excellent job, too
That’s looks great, see you went for the curly cable too. I was looking at that. I have emailed Roger about fitting some for me. I thought I could do it myself but want to be site I do the wiring correctly once I come inside. Thanks for the pic
Hi I had 200w panels on my t5 for the leisure batteries which worked really well but with my new T6 I’ve put in the EcoFlow alternator charger with a delta max so can reverse charge the leisure batteries if needed… I do mainly off road camping in Northern Europe and Spain and really do not miss the panels… I do have a EcoFlow external solar panal if needed but I’ve never used it yet… just sharing my experience …
As with every option for a Cali, I wouldn’t rush into buying Solar. I’ve had a Cali for a couple of years now and while I really ‘wanted’ to add Solar, I’ve not done so as I’ve just not needed it. For our useage, the fact that we’re touring around means that the leisure batteries are routinely topped up and it’s easy to manage 2 days on leisure batteries alone.
I’d agree with this. We did “rush” to add solar, and while I’ve never regretted it and it give us peace of mind, we’ve never really needed it apart from one festival.
The main benefit for us is actually at idle - the van sits on our drive for long periods and the solar just keeps the leisures and starter topped up in between trips.
Hello!
Bought solarpanels from german Califaktur for my California Ocean T6.1.
Epic quality and performerance. Highly recommended.
Hello!
Last year I bought solarpanels from german Califaktur. Epic quality. Highly recommended. Good customer support
Kind regards,
Ulf
Lovely thank you!
I’d avoid Solar Camper Solutions like the plague. I had a terrible experience with him after he supplied two panels, both of which failed within 18 months. I replaced them with a Renogy panel which has been brilliant for a few years now. Roger seems to have a few fanboys on here that pop up whenever customers share their negative experiences. There are plenty of other fitters out there as it’s a very easy thing to do.
Thats interesting , ive only had good experiences with them and TBH not seen the negative comments but will monitor mine now to make sure all good. Glad you got a good replacement.
I suspect your experience is not one shared by many on this forum who have had great experiences with Solar Camper Solutions.
That’s a really interesting comment. I have started to think the same about them. At home the camper has been on charge since I collected it, when not being driven. So wouldn’t need them at home, when we are away I generally do have the opportunity to plug in or drive about and boost the batteries back up. I have been trying to think when I would really be ‘off grid’………I’m going to sit tight for now I think and really consider it once we are out and about. Thank you for your comment.
Had T6’s for 9 years never had / needed solar or levelling ramps.
10K
themagician
themagician
Gelato
14K
California_Ocean
California_Ocean
Dukeylabdog#1
Bulliturk
Bulliturk
Monty-Wilf bus
Roger Donoghue
Roger Donoghue
G
markab
markab
