Beep noise when unlocking 07 plate T5
BigPritch
BigPritch
Wirral
T5 SE 174
Have tried searching Forums, but can't find anything.
Is there any way I can disable the 'beep,Beep' noise whenever I unlock the van ?
Have to press the unlock button 3 times to get the side door open, which as you can imagine, 6 beep beeps, is annoying.
Is there something I can do with the Fob to change anything ?
Many thanks
To stop the beeping you will need a diagnostic scanner like Carista,OBD11 or VCDS to code it out. On my vehicle I coded the beeps for when my vehicle is locked.
Thank you, was hoping I could do it without taking it back to the garage. At least I know, thanks.
Mine only beeps on unlock.
If you go on the T6 forum you can ask a member close to you who has VCDS to code it for you, for a few beer tokens.
You can buy a Carista ODB2 dongle, and 1-months subscription to change things like open door beeps and mirror in/out actions on locking. You communicate with the dongle via Bluetooth, and the Carista application is straightforward. Once you’ve done your changes, just cancel the subscription. This is what we did to get rid of the annoying b
An added benefit, you can use the Carista without subscription in order to see how the particulate filter is doing. See this thread …
