Ocean 6.1 retrofit paddle shift..?
Had paddle shift on a T6 for 8 years, used it to downshift for engine breaking maybe three times, which is two times more than I ever used the sport mode. In a truck it is a complete waste of time!
Evening all.
Job done - and, rather handily, the vehicle even seems to have recognised the change of wheel and switchgear such that the paddles worked for me ‘straight out of the box’. . . so, in the end it’s just a simple case of removing the airbag module, steering wheel bezel (HUGE patience and care), fitting the new MF switch set onto and then swapping over the new wheel, reconnect battery and drive away !
How-to guide to follow.
Thanks.
View attachment 133564View attachment 133565View attachment 133566View attachment 133567View attachment 133568View attachment 133569
Thanks for inspiring me to get this mod done JR. Our recent trip to Scotland proved the shortcoming of just leaving the standard DSG setup and coasting function to get it right on steeply undulating roads, and reaching for the gear lever to knock it into manual, pick a gear and soon after push it back into auto is a PITA.
Some searching on the T6 Forum suggested that a MF steering wheel - part number 2G0 419 089 D VDH - with DSG paddles, would be a straight plug and play swap. I found a mint one on Fleabay for a bargain and took the plunge. I've done the swap and everything seems to be working correctly. I did have a heart stopping moment when I first switched the ignition on having reconnected the battery - the dash lit up like a Christmas tree with numerous ACC and sensor warnings. I did look at removing the silver bezel to swap the buttons from the old wheel but was rescued by a T6 Forum member who suggested that turning the wheel from lock to lock would likely clear the faults - which it did! Just need to work out how to delete the quizzical look from my better half's face on why we needed a new steering wheel now.
That’s truly excellent to hear, and thanks for reporting back !
I’m reassured that someone else i) sees the advantage of being able to command the occasional fingertip manual shift and ii) has a wife who is equally foxed at the pointless faff of doing the ‘upgrade’ !!!
Just two things: the Christmas tree syndrome when reconnecting the battery and firing up can equally easily be fixed simply by driving away for a few yards, or perhaps it is simply exceeding 5mph or so that does the trick ?
My wife was so disgusted and bothered by the irritating excrescences I had inconsiderately and inconveniently planted right where she wanted to have her fingers gripping (search me as to why ! - I only really rest the heels of my hands on the rim), that I went straight into a second wave of modification, so I now have no levers at all but just a smooth flush aluminium finisher plate on the backside of the spokes and my buttons are operated via touch through a dia 12mm hole with a rubber membrane to translate the contact pressure.
See photos below (the temporary tiny short wire clip I employed whilst I proved the mod is also now gone, so the whole thing is completely smooth to the touch).
(we did a week in Wales recently, and are now 2 weeks into a 5-week trip of Ireland’s Wild Atlantic Way - I can report I’ve done maybe 50-odd ‘mountain’ gearchanges with the super-discreet shifters, and I don’t think a single one was spotted, or at least commented upon (which had also been an objection when I shifted with the stick) . . . only problem now is the old wheel is resolutely stuck as an ornament on this forum, and sits at just 3 views on eBay !)
IMG_1035.jpegIMG_1034.jpegIMG_1036.jpegIMG_1047.jpegIMG_1048.jpegIMG_1068.jpegIMG_1051.jpeg
If needed, I might try shortening my wife's fingers instead
I just showed your comment to my wife, and she smiled and snorted - I think she’s clearly over the worst of the offence !
Evening all.
Thanks.
Hi there.
Did you do a full how to guide and parts list as i am very interested in this mod?
Hi there.
Hi.
To my shame I regret I have not, but it wouldn’t take much to complete it - let me get on to it !
Meanwhile (and maybe better) if you’d like me to talk you though it - it’s really dead easy - then by all means message me directly and we can have a chat about it.
Thanks.
Let me know !
Hi there.
Without wanting to steal any of JRs thunder, maybe also check my post above, the wheel I fitted came from a Caddy and was a straight swap - my post has the details
Evening all.
Thanks.
Did you have to remove the power supply to all three batteries or just the one under the bonnet?
Just the starter battery, leisure batteries have nothing to do with anything forward of the front seats
Hello.
Indeed, as 'Sheffield10' says, there's no need to disconnect other than the main engine bay battery . . . and that is only a belt-and-braces precaution, given that you isolate the airbag as soon as you have access.
(I guess isolating the battery does guard against the risk of a very spurious and highly unlikely signal from a faulty loom, control box or sensor commanding the airbag to inflate . . . but with the ignition off, this does seem very far-fetched - anyway, unhook the battery* !)
Have you done a paddle-shift steering wheel retrofit then, or at least are contemplating one ?
Best of luck !
* I mentioned somewhere above in one of my original posts that the rash of warning lights which come up when you first fire the engine after a battery disconnect will all self-resolve once you drive for a few yards, exceed a threshold vehicle speed or time duration, . . . or whatever !
I’ve had flappy paddles on 2 of my Cali’s.
Love the idea of them, never used them once (except for testing)
Watching the heated steering retrofit with interest.
To test and never use ? :)
