T7 Ocean Battery Upgrade
blind_oracle
Switzerland
T7 ocean
So Ocean has two 40Ah LiFePo4 batteries behind the fridge, and around/between them there's a lot of free space. I think one can easily fit 140-150Ah single one in there.
Problem is that the batteries seem to be connected to the car over some data buses (from their BMS?) and I'm not sure what would happen if I just replace it with a "dumb" battery that doesn't talk to the car. Has anyone tried that yet?
Interesting idea, I’d have a go if it was possible
For testing I've plugged a 80Ah LiFePO4 battery in parallel with the ones that came with Cali. So it's now (40 + 40 + 80), double the capacity. First, of course, one need to equalize the voltages.
I've put it into the cupboard above the battery compartment - it has a removable shelf with a fuse box under it. One can remove the handle from this shelf (non-destructively) and get a hole through which you can pass the wires to the cupboard.
Overall it works fine, the load is spread more or less evenly between them since the capacities (that is - internal resistances) kinda match. The only downside is that when looking at the charge/discharge current on the camping dashboard or in app you will see half of it, since it reads directly off the batteries it seems and doesn't see the 3rd one.
In a 2-3 weeks I should get 230Ah cells and will try to use them instead in parallel, they should also fit into a cupboard. The capacities won't match, but it shouldn't be a problem probably. Only the current in the stats will be much off.
good stuff, if you could post a few pics to show what you have done/doing would be very helpful
Will do more photos once I get the 230Ah ones.
Currently there's not much to see, just a box with a battery hooked up using two wires to one of the original batteries below:
That's how stuff looks under this shelf (solar controller lives there for now, I've posted about solar in a separate thread): 1767550361622.png
battery is connected via CAN you won’t just be able to plug n play. I believe any battery change would have to be coded in to the vehicle if even possible?
Yeah, that's the reason I am currently going in the direction of adding parallel battery.
I have somewhere the CAN analyzer, maybe if I have time at some point I will try to decode the battery protocol and emulate it...
This is logical as your not replacing the battery, your just adding capacity, so in theory the system will not pick it up :thumb
Yup, but if I want to see the real (dis)charging current and whatnot I will have to convert my battery BMS data into something VW controller would understand...
So the T7 uses the BMS data from the Lithium batteries for its display?
Who makes these Lithium batteries.?
Is the BMS data provided in a standard format or is it VW specific?
If it is VW specific does the manufacturer make a larger capacity battery?
1) Yes, it seems so. The batteries have additional connectors for data bus (CAN probably). When I connected another battery in parallel which was with a bit higher voltage - camping screen showed a burst of current flowing into leisure battery while they equalized.
2) No idea, the stickers say VW, but probably some OEM. I couldn't find anything online
3) Also no idea, probably VW specific, but I haven't sniffed it yet
4) Well at least officially there's no larger capacity
I've added a 230Ah LFP battery in parallel, been using it for a few months now.
Some notes:
* It works fine, gives no problems to VW systems as expected
* The internal resistance of the cells seems to be different from the T7's built in batteries and they charge/discharge differently. This leads to a situation when e.g. the bigger additional battery has still 50%+ state of charge, but Cali shows that the internal one is <20% and Cali goes into power saving mode (disables fridge etc).
* So ideally I'd want to remove the built-in batteries altogether and just use the big one, but since they have some data bus to talk to the car - it's not that easy. The bus is a single wire (to each of 2 batteries) and I dunno what the protocol is, needs research.
* The built-in batteries are made by A123 systems
I'm very much interested in more info about adding/replacing batteries. So far, I'm carrying 1300wh powerstation. But if the internal batteries had more capacity, I'd love to ditch it. Especially because the car can charge the internal batteries with exceptional speed.
Btw: is there a circuit breaker to disable the inverter? I'm not using the 240v power plug and I guess the inverter must consume a good deal of current even when not in use. (that is at least the case with all powerstations.i i believe it must be same with the built-in one).
The inverter has a sensor in the socket, so that it turns on only when something is plugged in there (the LED turns on near the socket when it does). So when there's nothing plugged it shouldn't eat anything.
Oh, wow. I would not expect this level of sophistication from vw. (but it means that I can't leave a mains cable plugged in there :-(
It’s also worth remembering the 300w limit on the inverter. This is where power banks win in my opinion. I use an Ecoflow Delta between the front seats and it’s fits perfectly.
I'd like to get dif of my powerstation. Storage space is lacking and I like to have a free way to the back between the front seats...
300w is not limiting for me. I use it for ebike charging and my charger consumes just 200w maximum..
But youn know what? I might try to place it beteween the seats. Maybe it wouldn't limit the front - back motion completely
I just made a thick cable with XT90 plug that comes from the big battery that I added. And if need be I connect a bigger inverter (2kw+) there to run coffee machine or whatnot. Not really flexible, but well...
I find anything between the two seats, I’m always tripping up on.
Be it, EF in a 6.1. Or the right size really useful box.
Small 2” high box for snacks on my Laika 7.4m Moho.
I really like to keep it clear.
I’m really hoping with a seat removed in the t7 beach I can store porti potti and the Delta EF.
Will test it out once the beach arrives.
