Front USB ports - charging problem?
blind_oracle
Switzerland
T7 ocean
So I recently got a T7 and hooked a phone (S25 Ultra) to use Android Auto. All worked fine, except that the phone was discharging faster than charging... eventually it just turned off. Though it was saying that it's charging.
After power cycling the phone & turning the car off and on nothing really changed. The same phone in my other cars charges fine.
I've tried USB tester and it does show that the port indeed advertises 45W USB PD, but something is fishy here...
Anyone had any problems with USBs? And yes I've tried both forward ports.
Rear ones seem to work as expected so far.
Mine is also doing same with 2 I phones ie only intermittent charging all others are fine in the van also T7 did u get it sorted?
Mine is due tk go bam for warrenty work.
We even bought new leads no difference
In my case just changing the cable seemed to help. I've bought some very short like 30cm ones for the front ports (to put phone on the shelf above) and they seem to work fine now.
