Hanging a Bike rack in the garage
Lost Boy
Lost Boy
Surrey
T6.1 Ocean 204 4 motion
I wondered if anyone had used one of these on the garage wall to hang a Thule XT3? I'm running out of space in the garage so I'd like to hang it on the wall by the towbar clutch but am somewhat terrified that it might fall off and damage one of the other cars. reviews on Amazon look OK, apart from one. Anyone done this? Rack is about 21kg, wall would be brick not block, using expansion bolts x3.
Not got but your install method would be more than sufficient.
I have got one screwed into a wood beam, with MFT back back box attached to it. Solid as a rock.
If you are worried just set some threads in the wall with resin, then bolt onto those. But 3 x expanding bolts should be more than enough.
Thought about this and how easy it might be to support, unlock using the lever and lift it off*
Went for two suitably large plastic coated square channel hooks from Toom / Obi / B&Q for an XT2. Just fold the upright bar flat and hang it from one end. Stores vertically.
*It's probably easy, just didn't try it...
Is it strong enough to hang from the end, I wasn't sure given the XT3 is bloody heavy over 20kg and it looks like the ends are only riveted on. assume you have had no issues?
I do have space at the sides and would rather not risk it over the car but will advise how I get on with the towbar mount, its ordered now but have some brackets I could use also. Thanks.
