Leaking Bellows. Strange situation
T
Top Diner
Emsworth
T6.1 Ocean 199 4Motion
Apologies if this is not posted in the right place. So, the saga of leaking bellows goes on. I had my OS4 bellows replaced on my T6.1 this week. I was expecting them to be replaced with OS6 bellows BUT they were replaced with version OS1 that were manufactured on 12 December 2024. What are the views of Forum members. Have I been sold a pup by the main dealer who did the work? It does seem very odd. Any thoughts would be very welcome. By the way VW agreed to replace the OS4 bellows but I had to insist and threaten legal action against the garage and VW.
I don't know what 01S version is. On the standard grey coloured bellows, 03S were fitted during 2023 manufacture before being superceded by 04S 05S and finally 06S.
There's something definitely odd with 01S manufactured in December 2024.
You know if you have the 06S version equivalent fitted because when it's opened, on the two front vertical seams you will find a transparent stuck or ironed-on seam sealer.
If you've got that you've got the latest and greatest.
And well done for having a go at VW. They really do take the p*** with their meaningless warranty. Never thought they could deny issuing new bellows and survive a small claims court. Or even risk a summons.
Thank you for your reply. The main dealer could not explain the O1S ticket either. They are investigating. I do have replacement bellows with seam sealer on the vertical seams so I could be in luck. As for VW Warranty, I agree with you that defective bellows or indeed anything else on a new or nearly new California should be covered. There is also Consumer Protection legislation which is relevant to the dealership that sold the California. I will update this thread when I get clarification on the OS1 ticket on what could be an OS6 set of bellows.
So, I have a feeling that when the T7 was launched it launched with 01S bellows.
Maybe they're compatible and that's what you got.
Seam sealer is a good sign!!!!
If they are dark grey on the outside and light fabric on the inside, with taped corners, they are the same as 06S bellows. What colour are yours Top Diner ?
They are a mid to dark grey on the outside with a very light grey on the inside, with what appears to be clear sealant on the vertical seams but not the horizontal seam ant the bottom of the semi-circle opening on the front of the bellows. The O1S ticket is causing some consternation at the main dealer and at VW UK Customer Services. I will update the Forum when I have more news as I suspect the bellows saga will run for a while yet.
Just to inform this thread: our new T6.1 (delivered Jan '25) had problems with leaking seams, etc. We followed some advice from here on another thread of wetting it, then hoping the threads in the seams would expand naturally, thus curing the problem, but to no avail.
I brought it back to the dealer with photos of the leaks (actually easy to see on the photos) and there were no quibbles about replacing it. The first replacement was marked in some way - I didn't see it, but the dealer said they weren't happy with it and had ordered another. I left it the van with them for another week and it was returned with an 06S fitted last week.
The difference is notable insofar as the seams around the front opening were not stretched (you can see light by the zip in the attached and the drip running down beside it on the original bellows), but I have yet to test it in the wet, which will probably be this weekend coming - the odd occurrence
that you hope for rain!
I have had exactly the same problem. See my posts below. My new bellows had a OS1 ticket on the front opening zip. Very strange and currently still under investigation. Did your new bellows have an identification ticket? Do they also have what looks like a clear lacquer seal running along the vertical seams? Maybe post a photo here?
Hi, Yes to both - I have the ID ticket, and the seams have the seal on the vertical seams, but not on
Jef4130
T
Viktorgeorge
Viktorgeorge
F
10K
OooOooTheMonkey
OooOooTheMonkey
