pematthe-1967
My 2017 Cali Ocean (spec'd for Denmark market, sold in Germany, now in Slovenia!) didn't come with Parking sensors. After some discussion and threads on the T6 forum, A company, carsystem.eu in Poland, were recommended as supplying VW parts in kit form to be able to retrofit front and rear sensors, module and all ancillaries. All I had to do was worry about programming.
I took the plunge and purchased a kit. Sure enough, all the hardware is VW (sensors, module, beepers, switch) except the wiring loom. The instructions are appalling and are from an unrelated German company that seems to supply all the bits but as separate items. The document supplied is vague, misses out fitting the rear sensors completely and has you soldering into the wiring system and stuffing modules behind dash panels. Not quite plug and play into the vacant holes where PDC should be.
The sensors in the bumper are in. Removing the bumper covers and drilling was a bit daunting, but manageable, Routing the wiring was more difficult due to the lack of instructions but again, was manageable. I am now stuck with making the final connecting in the cabin area.
Here come the questions....
Haven't even thought about programming yet!
I am also going to ask the same on the T6 forum, seeing as that is where the info for the kit came from in the first place.
- Anyone else done this before, specifically with the kit from carsystems.eu?
- Anyone have info relating to where things should go and be connected inside the cabin?
