2CV67
Obviously the Cali, with all its equipment, has great potential for rattling & squeaking!
We quickly fixed the prime culprits:
- by learning to push the sliding table towards the fridge before clipping it back.
- by winding the awning in tight.
- by keeping beer & wine bottles & jam jars in cut-down plastic water bottles to avoid glass-to-glass contact.
- by using anti-skid mats on the shelves.
- by fitting carpet-tiles in the cupboards.
We also found little rattles from:
- the loose handles on the awning crank (padded with bubble-wrap).
- the adjustable foot of the table in the sliding door (screw up tight or add bit of rubber tube).
But now we are left with one significant rattle, which seems to come from the bench seat near the sliding door (or the sliding door next to the bench seat?).
I suspect this may be coming from the mechanism for clamping/releasing the seat, but am not sure.
I removed the big drawer, expecting to be able to reach the mechanism, but couldn't.
So now the question is - how to get at that mechanism?
Can I just pull off the plastic cover at the side of the seat & if so - how?
Or what else?
All suggestions welcome, on this & other noise issues!
Or what else?
Last time they replaced the entire seat base which has improved but not cured the problem. For me its quite a metallic crash when on rough roads or potholes. Is yours the same? If I slide the seat forward it happens less, probably because the rattly mechanism is further away from the rear axel.
