Iso-Top
Norfolk Jim
Norfolk Jim
Finally retired at last.....................
Norfolk
T6.1 Ocean 204
HI everyone.
I'm considering an internal Iso-Top for my Cali T6.1. It says it can be left in place when bringing roof down but how easy is this as I find mine material ends up very tight above shutter which is sometimes hard to close. How does the additional bulk of the liner work/fit.
I'm very careful always when bringing roof down and carefully fold front ino a 'U' shape when closing to ensure shutter closes - is it as simple as it says especially if no one can be outside to make sure bellows doesn't catch in scissors.............................
Advice very much appreciated before I buy it as appears no one has a used one £££'s
My understanding is these internal iso-tops are designed to fold with the bellows. I recall a video from the Cali now Camper Time double act where they fitted one. We opted for external instead so we can chop and choose.
I have one on my T6.1 Ocean. Each time I drop the roof I just remove the front panel, which is a 10 second job. The rest remains in situ.
It works great in terms of heat retention and also makes the roof bed nice and dark for sleeping. It's not cheap, but it's great. A real game changer.
Do you use a bellows bungee? Might make our life a little easier.
Same here, on advice of my dealer, after having trouble with my front slider (it got loose).
No need to remove anything, just leave as is when raising and lowering roof. Hassle free insulation and darkening
That’s what I do with my older T6 version. I think the newer one for the 6.1 the zip out front needs to be removed? The 6.1 has thicker pop top canvas too I believe.
We have it in our 6.1 with the newer thicker bellows. Only thing I do is open the left and right zippers of the front piece and close the roof. All fits well.
Verzonden vanaf mijn iPhone met Tapatalk
Thanks. I do have one but not used it yet.
Thanks everyone, so I need to keep eyes open for one in Used Accessories lol or stump up the £££......... The main reason is for taking dog away we can't use lower bed as he's simply to big!!!! He sleeps stretched out which was fine when we had a conversion as no draw under bed when bed laid flat. We'll also need ladder fir Mrs NJ to get up there!!!!
I’d be careful using one on a 6.1. They well known to be useful for the 6 and below but feedback on here seems to be the new fold areas for the 6.1 means they are not needed and could cause damage.
I use the WG method and stick my head inside to check. The front piece seems to cause initial frustrations to many but most find their own method to fold.
Steve P
RosscoPCole74
Lee.Van.Cleef
Lee.Van.Cleef
RosscoPCole74
RosscoPCole74
RosscoPCole74
Borris
Borris
