View from/of your van.
And, is it my imagination or are there fewer and fewer stations offering a bucket and squeegee these days? I know that we don’t have as many bugs to hit windscreens in the UK, but even the hot countries seem less willing to help the driver in this way.
The garage I usually go to in Spain always cleans my screen after putting in fuel. This garage put in the fuel but I had to clean the screen myself, an interesting exercise as I am only 5ft tall. I stand on the door way and to drop water on then use a long cleaner. If really bad I get out a step. I also squirt water or cleaner at the screen. It must look odd. At least Spain still has bugs. This was in a wine area.
Camping Einwaldli in Engleberg Switzerland.
Nice view and van, is your high top insulated, that's the one issue we find using the pop top in late season / winter.
Thank you! Yes, it is insulated for the most part. I used to have a pop top van, it as I work in my van 4 days a week year round I swapped to this for that reason. However, Westfalia didn’t do a perfect job and some sections can get colder than others so I had to do some additional insulation myself.
The front cab area roof wasn’t well insulated and I had to add additional to prevent the foot area when sleeping getting cold. This required taking out part of the upper beds frame to add some, but was only necessary as I’m sometimes in areas with -10C to -20C in peak winter.
Some of the side and rear areas of the door panels can also get colder than others but this isn’t as big a deal with the dual zone diesel heater. I haven’t modified those as additional insulation adds weight and I wanted to keep the available payload. Overall it’s great as is in cold winter, and having a hot shower in a small van like this is a dream.
Thanks, we use our van during the winter for skiing and find the lack of insulation and issue, but it's never stopped us . Using the topper in winter makes a big difference.
Absolutely! I’m a data driven person so added Ruuvi tags in all the areas of the van I wanted to monitor temps (and get alerts on my phone if something is off). Last night was just below 0C. This is what I see now:
I do like that, never heard of those before, I'll need to Google that one.
They are awesome. Just make sure to get the IP67 Pro ones for anything outside that can get wet. I also used those for inside the fridge and freezer. Anywhere else I use the standard ones for indoor.
Just had a look at their website, battery life seems short, how do you use yours?
Let’s drop into a DM so we don’t disrupt the thread and respect others. I’ve had the batteries last on average 1.5 years before swapping out. Not expensive and not a big deal.
I used the standard one inside my fridge and it works well for 18 months now. I have the pro on the roof though, I’m thinking of adding another pro underneath the van as you suggested for a better exterior ambient reading. The one on the roof gets cooked in Summer!
Just be careful as there are different Pro models. Only the 2in1 IP67 one is suitable for under the van.
YorkshireHeathen
YorkshireHeathen
BruceMorgan
Beachbum140
9K
Bulliturk
Bulliturk
