Mounting Tape
markab
markab
Suffolk, UK
Grand California 600
What mounting tape is everyone using to stick pictures and other bits to the textured plastic trim around the bins above the table area and above the hob?
I did try unbind no more nails blue foam mounting tape but it seems to fall off now its getting cold.
IS 3M VHB ok to use on these interior panels?
Same here! We’ve tried 3M Command hooks and they mostly fall off. Whatever the surface is, nothing sticks to it !!
Nano tape will stick to textured plastic and can be removed with no residue
3m vhb still falls, i had a bin on magnets that were stuck to side of the passenger seat but they kept falling off, best solution so far was hot melt glue, but they still fell off eventually.
We have the Brandrup spice jar holders mounted next to the 240V sockets which are held on by heavy duty velcro which can be obtained from Campervantastic if necessary.
Ok, I am giving VHB a try now, see if it lasts.
Always worth cleaning with alcohol wipe or a de greasing agent etc before using anything self adhesive.Will definitely help it to stick
I tried that but it still fell off, im talking about the lower sear mouldings. Seems to be a oily plastic with a textured surface that just dont like tapes. As said before hot mellt glue worked best but still fell off eventually. Dont really want to drill holes.
Have look at this vid in the advert
It does what it should do Stick like sh#t to a blanket, but then can be removed without trace
I just found this on AliExpress: £1.64 | 1-10M Nano Double Sided Tape Heavy Duty Transparent Adhesive Strips Strong Sticky Multipurpose Reusable Waterproof Mounting Tape
I remounted everything with VHB after cleaning down with isopropyl so far so good
