2012 Tyre Pressure Sensor - not resetting
T
thanksbye
Surrrey
T5 SE 180
I’ve tried with the search but no luck.
I’ve had my Tyre pressure sensor light come on .
Tyres at the same pressure on all four corners, but when sitting stationary I cannot get the light to reset using the reset button on the dash.
It worked last time the issue came up.
Is there an easy way to see if it’s the abs sensor and if so which one? No other error codes or warnings showing
You need to check diagnostics with an OBD reader, Carista or OBDeleven.
I’m not finding any errors with the Carista, nor differences in the wheel speed.
Anything else I can check or is it now a garage job?
Try this.
To reset your VW T5 tyre pressures, first inflate all tyres to the recommended PSI (check door jamb sticker), then use the buttons on the wiper stalk or steering wheel to navigate the Multi-Function Display (MFD) to Settings > Tyre Pressure > Store, confirming the new pressures. If you have a button in the glovebox, hold it down with the ignition on (engine off) until you hear a beep and the light goes out; otherwise, use the MFD menu.
