charge tie down anchors
Bongoloidfloyd
Bongoland
Hi,
The 2 rear tie down points seem to not be supplied, there is a plastic cover over a screw/bolt bead but no hooks/lugs.
I’m sure that I saw somewhere that a guy had bought clip in logs but I cannot find it again.
Any pointers please?
(Did a search here but nothing I could find)
:help
I don't understand what you're asking? Is this about the awning?
:help
Aiutocorrect was not my friend!
I’m looking for some rings to use to tie down luggage and shopping. When you open the rear door lid there are 2 circular inserts on the floor where I would like to clip a luggage net onto. I can then use the sliding lugs that’s are provided for the seat rails and stretch a net out to hold everything in place.
I was able to remove one of the plastic covers on the 2 rearmost points but no ring/hook/lug underneath. Is there a replacement with a metal ring available?
I am pretty sure these will be fouled by the chair storage bag when the boot is closed. This is the reason they have been taken out the California but remain in the Multivan.
Ah okay. I must admit that our boot is always filled with camping gear. Our supermarket stuff goes in the van, and yes it does roll around a bit!
