RetroRed5
@RetroRed5, available in red too:You could get a reel of self amalgamating tape and make your own. Wrap to desired thickness and length. When wrapping the tape stretch it quite a bit (as in a lot) as you go. The tape blends together and will becomes a solid lump of rubber, screwfix do it I think. Or find something like water pipe with right internal diameter, cut to length and slit, if it is slit spirally that will help.
Good tip - thanks.You could get a reel of self amalgamating tape and make your own. Wrap to desired thickness and length. When wrapping the tape stretch it quite a bit (as in a lot) as you go. The tape blends together and will becomes a solid lump of rubber, screwfix do it I think. Or find something like water pipe with right internal diameter, cut to length and slit, if it is slit spirally that will help.
Nice find. A link would be good, if you could?
Starter for 10 linkyNice find. A link would be good, if you could?
Here you go...Nice find. A link would be good, if you could?
25 mm sized ? many thanks for the linkHere you go...
10pcs Chair Leg Pad Damper Stool Anti-Front Tilt Pipe Clamp U Shaped Floor Glide | eBay UK
Keep your couch,chair or desk from leaving a big dent in the floor when nothing is under the legs. No need to stick, simple to wrap and not easy to fall off. Plastic material in black color, and conical shaped design for standing steady.www.ebay.co.uk
Cool, many thanksYes, I ordered the 25mm version; they've not arrived yet so I can't comment on how good (or bad) they are; will update once they do.
Thankyou for your continued researchBit of an update...
These widgets arrived and while they sort of work, they are not great to be honest; to get them to fit you have to cut off the raised pin part that is on the inside edge (or else drill a hole in the leg of the Cali chair)...
Once on the chair, they a little too flimsy and narrow and consequently move around a bit.
I have found an alternative, once they arrive I'll let you know if they are any better (or worse).
Can't you slide them to the middle of the bottom rail for storage then slide back when in use? Or twist them 180 degrees when stowing?So the new widgets arrived, good news and bad.
First, the good news, they are the perfect fit, just as if VW had included them from the factory...
They are wider and much more solid with a tighter fit than the first attempt, and they don't have the little sticking out thing you have to cut off - result
Now for the bad news, when attached to the chairs, the chairs no longer fit into the tailgate! No amount of chair wiggling will get them to go in
Since I'm somewhat OCD with my Cali, I've told myself I'll keep eight of them in a little box in the Cali and I'll just fit them every time we use the chairs but even I may tire of doing that.
Anyhoo, if you want to get yourself a set, here they are...
Amazon.co.uk
www.amazon.co.uk
