New leisure batteries not holding charge
Calibrator
Hi, I replaced my two leisure batteries about 2 months ago with Varta LA 80 AGM and all seemed well. I noticed that batteries were draining even though I haven't been camping and using them.
I have hooked up van to charge them a couple of times until they showed 100% but they quickly revert to 90%
Returning from a week away I checked control screen and batteries were showing 30% and -O.2 Amp drain, see photo. Clearly something isn't right.
Any advice?View attachment 141675
-0.2v is the Control Panel screen consumption. Drops to 0v when screen goes Off.
As mentioned make sure nothing is plugged into any 12v socket.
Lift up flap on the aB pillar inverter socket. Is the LED lite, top L under cover.
Hi, nothing plugged in anywhere. Which is the aB Pilar inverter socket? Is that the 240v euro socket on side panel trim behind passenger seat?
Yes. That’s it.
Hi, nothing plugged into it but there is a green light glowing. Should that be on?
Check you never blew the cube fuse on the rear battery pole. If the batteries were at different states of charge when connected, the imbalance might have blown the fuse, halving your capacity
That is possible. I assume I can check this by testing continuity across fuse.
No. It should only come on when a plug is inserted.
Insertion of a plug triggers a microswitch to switch the inverter On.
I would suggest the following.
Use the appropriate plug to trigger the microswitch , hopefully to Off.
If you are never going to use the Inverter then remove the fuse. It is a 30 amp fuse under the Front Passenger seat, in front of the Leisure Battery.
As a test remove the 30 amp fuse and check that the LED goes out. Do the batterries now last longer?
Many thanks for this advice. I got a shock from the socket when I lifted the cover and inadvertently touched the exposed conductors and couldn't see how this could be in child 'safe' mode.
I don’t understand. There shouldn’t be any exposed conductors.
This is how the Inverter socket should look and the type of plug adapter used.
View attachment 141687View attachment 141688
Now you mention it, I thought it was odd to get a shock from a socket so have just been out to examine it and discovered what appears to be the ends of an adapter like yours plugged into the socket. We had one and not used it for years and it looks like it could have been broken off when sliding seat back leaving pins in. This explains why LED light is on.
Would this be sufficient to drain the battery in a short time?
It certainly appears to be the case. You'll need to remove that, possibly with rubber-handled pliers gripping the middle plastic part as above. This should mean the microswitch then turns the inverter off, and stops the draw. Inverters do use typically around 20w or so, so negligible for an hour or so, but if on 24/7, then yes...
Yes I will do that, thanks for your advice. I think I will also check the cube fuse to make sure both batteries are in use.
Yes, I'm afraid.
Yes. The fault was caused by failure of small self tapping screw securing the housing holding the twin pins into the socker adapter. I have removed the pins from socket and glued them back to the adapter body. This was resulting control panel reading. It still shows 0.2 A drain even with green light of inverter now off. Presume this is current powering the control panel?
AlisonF
23K
Joker 1299
Joker 1299
Andy N
R
happyjames013
H
