Cracked igniter ceramic
  • Thread starter Almost bought a california
  • Start date
Kettering
T6.1 Ocean 150
Hi All,
Can anyone help source a ceramic igniter for the hob - mine has a crack allowing the spark to 'leak' out and not spark from the tip. I have turned the electrode for now but will need to change it at some point and so far I have only been able to find a complete VW kit which includes the igniter button for an eye watering cost!
Any help would be appreciated.
Use epoxy resin on crack? (Araldite)
I would go with the hob ignition upgrade which is on a previous thread as the original system is poor, my hairs are only just starting to grow back with the constant flash over from slow ignition
See here:
vwcaliforniaclub.com/threads/pushing-the-envelope-stretching-calis-room-to-te-limit.14232/post-621509
(post 621509)
And have a look at Amazon for:
Onlyfire model F-BIR2005-PE1-EU (was 17 euro at the time).
Regards from Amsterdam,
Marc.
JB weld high heat should hold for that heat.
