Parking Sensor Fault
thepickles
thepickles
Leicestershire
T5 SE 140
Hi All,
My parking sensors have stopped working, all I get is a long single beep and a flashing button.
I have had a diagnostic from my local garage (see Pic).
I have searched for the sounder under the drivers side dash by taking the lower black panels of and I can hear it but not see it.
All help appreciated in locating the sounder.
2013 California T5.1 SE
TIA
Steve
Hi All,
TIA
Steve
Any help?
On a 2013 Volkswagen California (Transporter), the parking aid speaker (buzzer) is located behind the upper B-pillar trim on the passenger side for the rear system, and under the front passenger footwell's instrument panel for the front system. Accessing the rear speaker may involve removing trim, while the front one is near where the glove compartment is.
For the Rear Parking Aid Speaker:
  1. Locate the passenger side B-pillar: This is the pillar between the front and rear doors on the passenger side of the vehicle.
  2. Access the trim: You will likely need to remove the upper trim panel from this pillar to access the speaker.
  3. Identify the buzzer: The speaker will be behind this trim panel.
For the Front Parking Aid Speaker:
  1. Go to the front passenger footwell: This area is located under the instrument panel.
  2. Remove the glove compartment: You will need to remove the glove compartment to get to the buzzer.
  3. Find the buzzer: It will be on a bracket on the instrument panel, requiring you to squeeze tabs to release it.
Is t Ai brilliant, especially mixed with a good old cut-paste.
Any help?
Brill thank you
The point is, what’s the point?
I’ll happily bet the OP can type his question into Google FFS.
The purpose of forums like this is to seek out personal experiences and specific information on a problem.
If everything was just regurgitated Google then there would be no forum.
Doubtless you’ll have the last word.
Google bases it's answer on previous answers on this Forum and others , similar to the Search function but without the non- informative posts, as above.
I just had an egg and bacon sandwich, do you want that regurgitated?
I think you just need to treat it like it's an illness at this point.
Here's what Grok had to say... (and it's never wrong - unless it turns into MechaHitler - then it can be slightly skewed)...
Why People Post Constantly for "No Reason"​
Compulsive, seemingly purposeless posting often stems from psychological or social needs, even if the poster isn’t consciously aware of them. Possible drivers include:
  • Seeking Stimulation or Dopamine: Frequent posting can be a way to chase engagement (likes, replies), which triggers dopamine hits similar to social media addiction. A 2023 study on social media use noted compulsive checking/posting aligns with seeking instant gratification, especially in anxiety or ADHD. An X post described this as "mindlessly refreshing for validation" [post:9].
  • Avoiding Offline Issues: Constant posting can be a distraction from stress, boredom, or loneliness. Research on Reddit use found that excessive engagement often correlates with social anxiety or depression, where forums become an escape from real-world discomfort. A user on X noted: "I’m online all day when life feels empty" [post:33].
  • Compulsive Habits: Posting without purpose might mimic OCD-like behaviors or impulse control issues, where the act feels necessary despite no clear goal. This is less studied but seen in forums where users post repetitive, low-effort content (e.g., memes, random thoughts).
  • Social Connection Substitute: For those with limited IRL interactions, forums offer a sense of community. A 2025 study highlighted how people with social barriers (e.g., rural areas, post-COVID isolation) lean on forums, sometimes excessively, to feel connected. An X post vented: "I post because no one’s around to talk to" [post:0].
  • Habit or Boredom: Sometimes, it’s just a habit formed from routine forum use, not tied to distress. Enthusiasts in niche communities (e.g., gaming, hobbies) may post frequently out of passion or boredom without deeper issues.
When It Might Suggest Mental Illness​
Constant, purposeless posting could point to mental health concerns if it’s:
  • Compulsive and Uncontrollable: Feeling unable to stop posting, even when it disrupts sleep, work, or relationships, might align with OCD, anxiety, or ADHD. A 2021 study noted compulsive social media use shares traits with behavioral addictions.
  • Tied to Emotional Distress: If posting spikes during low moods or replaces healthier coping (e.g., talking to friends), it could signal depression or social anxiety. A Redditor described forums as a "trap" when they’re used to avoid real problems.
  • Seeking Validation: Relentless posting for attention (even on mundane topics) might hint at borderline personality disorder or narcissistic traits, especially if paired with emotional instability. An X post called out "endless low-effort posts" as attention-seeking [post:36].
  • Isolating Behavior: If posting overshadows IRL connections, it could reflect avoidant personality disorder or depression. A 2025 forum study noted over-reliance on online spaces can worsen isolation.
As a general response to some of the posts on this thread, if I was the OP asking for help on this issue, I would find WelshGas's answer pretty helpful. It is concise and directly addresses the issue. I would not be worried that it contained some AI content, in fact that would tell me that WG is adding to what he knows with a little research, all of which would make me more grateful for the reply. I also recognise that WG has a lot of knowledge and is therefore more likely to be able to sense check any AI research that he adds in.
I am not surprised that the OP responds with 'Brill thank you'
Fixed
Found the one under the drivers side dash and that wasn't the problem
So I replaced the one on passenger side door pillar and that worked
