Bed base is bowed!
sidepod
sidepod
T4 PopTop
For reasons unknown the bed base has taken a bit of a set!
I’m only 74kg wet through and the better arf sub 50kg.
Is this normal or just another 6 fail?
Only about 25% of your body weight would be carried by the bed board, unless you sleep sideways.
More likely a heavy weight on the bedboard whilst travelling.
Mine was warped and damaged from factory. I only noticed 3 months after collection when I took it out to fit the slide out drawer.
Of course Breeze determined I had damaged it
Could it have got damp by any chance?
To be clear, I am not suggesting that either you or your good lady have incontinence issues :mute
Only from the rear door seal leaking……..!!!
On a T6.1 it’s worth checking the attachment spigots, my rear LH one is loose. It’s a bugger to tighten as no space so the dealers can sort it next time it’s in for service.
