Which diagnostic tool
D
donboon
Bedford
T5 SE 140
I’ve just got my first VW commercial but it’s not my first rodeo. It’s the 2015 T5 California 2.0l Blue Motion Auto. There’s lots of mods and alterations I want to do such as improve headlights. I’m considering replacing the units preferably with LEDs and some advice would be welcome. From my limited research, this will require the right tool to register it; and some help from fellow experienced members.
Has anyone some advice please?
Depending how much coding you want to do VCDS from Ross Tech, only runs in Windows, is the Ultimate ( £250 ) followed by Carista/OBDeleven which have some limitations compared with VCDS but are cheaper.
Although some members do carry out such modifications , more likely " California" specific there is a lot more info and members carrying out "Transporter" modifications eg headlights etc over on the T6 Forum that caters for T5 upwards or the T4 forum that also caters for T5.
Regarding LED headlights, i believe there are numerous plug and play versions available. A Google search will throw up many options.
Some "may cause" bulb errors warning!
Here are a couple to get you going
I believe those are just LED DRL's not LED for main and dipped headlights.
I think if full LED headlights were available they may be illegal on that vehicle. Same as LED headlight bulbs
We had retrofit headlight units with ‘illegal’ LED bulbs our our 2012 Beach; cost approx £550 fitted at Bognor Motors. Made a big difference.
On our 2015 Joker we just fitted the Philips LED bulbs, also great and a fraction of the cost. It’s also worth switching sidelights etc otherwise you might up with mix of white / yellow lights.
Don’t change the indicator bulbs for LED, as will generate a warning light and double speed click sound when in the vehicle (although externally indicators work as usual at correct speed!); Cost approx £40:
Philips Ultinon Access LED car... https://www.amazon.co.uk/dp/B0CHX6TQV3?tag=unique09f-21
LED replacement bulbs are allowed within some other countries within Europe (including safety obsessed Germany), they are illegal in the UK, but you will be able to see where you are driving at night.
Both our van passed MOT’s with no issues, and never got flashed by other vehicles in the UK or in France.
Would try switching the bulbs first and see how you get on.
The U.K. stance on LED retrofit makes no sense , particularly when the benefits far outweigh any negatives used to justify banning LEDs in the U.K.
I have LED bulbs fitted at the front for my 2015 T5 Cali.
Mine is one without separate lenses/bulbs for high/low beam. It does have DLR. I even replace the turn signals.
I did notice getting flashed a few times in France last week but as the Cali tends to “sit down” at the rear, that could be easily solved by using the headlight height switch and lowering them a bit.
All ordered from French company LedPerf ledperf.com. No problems with OBD either.
If interested let me know and I will lookup the article numbers.
Benefits for whom, blinding on coming drivers ? you should always drive safely and if you have weak headlights then that means slowing down.
I don’t think there’s anything to stop you retrofitting led headlights, just that it’s expensive because doing it properly means you need to replace the whole unit with an approved aftermarket one. My understanding is that LED bulbs need a different reflector so just replacing the bulbs results in an illegal/dangerous beam pattern. Seems entirely sensible to me.
Beam test is carried as part of an MOT.
Doesn't matter. If involved in an accident at night the Insurance company could void your Insurance because you could have fitted the non- legal LED bulbs post MOT and you would have to prove that the MOT tester had carried out the test with the LED bulbs in place , which would have been contrary to the regulations.
Thank you all for your replies. I’m aware replacing halogen for LEDs is illegal and I’m the first to complain when they blind me. I was hoping there might be a straight forward replacement headlight unit that uses LEDs. It’s expensive I know but a safer route. Failing that there are some LED kits that fit alternative headlight units that work without failing the M.O.T. So anyone with advice please.
Going back to the question of which diagnostics tool would deal with fitting a replacement headlight unit. It’s because I was told that changing some parts, headlights included, required registering with an engine management unit or some kind of ECU?
I know diagnostic tools will read and some reset faults but although I’m not familiar with VW I can understand that it might be necessary to teach the management system about a different device that’s being fitted especially especially when it’s likely to affect variables such as resistance and voltages.
Thanks for advice, please let me know the details.
Thanks for helping and I support your arguments about illegal LEDs. I don’t have Windows anymore although my Mac will and can operate both it’s not worth the hassle of constantly updating. £250? Well worth it if it does the job. Can you consider any similar devices that run on IOS. I do have an android tablet (Honor 9) but it doesn’t run windows as far as I know.
I'm no expert but OBDeleven seems to be the favoured Diagnostic tool after VCDS followed by Carista on the T6 Forum where members seem to be more into coding changes of the Transporter electronics.
Before you would order any, check out what type of headlight you really have. Halogen single lens, dual lens or even Xenon.
I have halogen single lens.
DLR: https://www.ledperf.co.uk/pack-led-...wagen-multivan-transporter-t5-wit-p-5688.html
Headlights: https://www.ledperf.co.uk/high-pow...it-for-vw-multivantransporter-t5-p-13463.html
Low beam
High beam
Side lights: https://www.ledperf.co.uk/pack-sid...olkswagen-multivan-transporter-t5-p-3690.html
Difficult to see:
Indicators: https://www.ledperf.co.uk/pack-front-led-turn-signal-for-vw-multivantransporter-t5-p-7316.html
I also have some rear number plate lights, no picture: https://www.ledperf.co.uk/pack-led-...olkswagen-multivan-transporter-t5-p-3691.html
Instructions for mounting come with it but are partly in French but with pictures. It is a bit of fiddling as space is tight.
From what I saw on the respective websites, both OBDEleven and Carista come with an app for iOS.
And Android. I run Carista on an iPad and a Samsung S10. Carisra works well with both operating systems.
Once again thank you for your advice. My apologies but being my first I’m probably mixed up with names. I stated mine van was a California but it seems it’s the SE. Now they might both be the same or similar but eventually I’ll get it right. With that sorted perhaps your advice may change.
There are 2 California models of your era.
SE , full camper with kitchen wardrobes etc.
Beach, 2 or 3 seater with pop up roof, not hydraulic, and NO kitchen or wardrobe.
Both have roof beds and a bed downstairs using the seats.
I’ve just looked at the OBDeleven and it appears to use credits, in other words subscriptions. I get the reasoning due to licensing and Intellectual Property Rights but that’s why I’d rather buy a full set of spanner’s than pay rental on an adjustable. The trick is to know the full extent of our needs and buy accordingly. Fortunately there are many people willing to share and exchange their knowledge so I’ll eventually get the tool that’s most appropriate for my abilities and needs.
Mine is full camper with kitchen fridge and cupboards along nearside of van. It has the upper bed also. Two front seats (captain) that rotate.
It’s got cruise and parking sensors and 16 inch wheels.
One of the downsides I’ve found is it has a basic radio and cd player. No satnav. To cope with that I’ve bought a sit on dash 10” CarPlay with built in gps that works well on my Land Rover Discovery 4. However I’ve since been told I can buy a replacement unit for the radio although reviews don’t look good for the Kenwood.
Absolut5 is a Forum member who specialises in the VW Transporter, on which the California is based, and are experts in Infotainment systems. They are very helpful and would advise on the best equipment within your budget. They can fit or send a full plug and play kit for your vehicle.
Headlights: https://www.ledperf.co.uk/high-power-bi-led-conversion-kit-for-vw-multivantransporter-t5-p-13463.html
Low beam
High beam
Side lights: https://www.ledperf.co.uk/pack-sidelights-led-xenon-white-for-volkswagen-multivan-transporter-t5-p-3690.html
Difficult to see:
Ok it does look like you’re using LEDs as replacements for halogen and these aren’t legal in UK. Probably not an issue elsewhere in EU but definitely a NoNo here in UK. At best I can use uprated halogens like Osram but without knowing I was hoping a different van might be compatible and more with modern times. The dealer who sold me the van has admitted using a later light module fitted with LED’s and whilst admitting they aren’t legal he also said they aren’t detectable and don’t cause light splintering. I’m simply too old to risk losing my license so I’ll consider his advice with caution.
Thank you. That’s really helpful and I can’t wait to contact them. My iPhone may be good but screen isn’t as big as I need for satnav.
