Sparesafe bolt cap
Milly
Milly
Knutsford
I recently tried to take off my sparesafe to check the bolts and found taking the silver cap off the bolt virtually impossible. Resulted in my spitting the plastic cap remover tool. on closer inspection the cap is too big to fit in the plastic tool. ?anyone else had this issue and any tips on how to get the silver cap off would be good - just picturing removing this on a dark rainy night. Thanks IMG_5743.jpeg
The plastic tool is tapered, the cap is an interference fit so the plastic grips the thin metal cap.
It's not the best design given the cost of the spare safe.
Mine has split , which appears to make it grip the cap better , it will eventually break though.
The Club shop may be able to supply replacement.
If you find a replacement post here to help other in future
Hi
The black plastic tool supposedly fits the thin silver metal cap. When pulled off(my issue) it reveals the sparesafe bolt which will undo with the supplied ‘key’ .There are two bolts the other standard hex. When loose the frame jigs to the right and drops down allowing the wheel to be accessed. This is said to be difficult if you have a rear flat!
I failed at step one on this occasion so others may have better knowledge!
Thankfully I have never had to do this in anger either but maybe a try in the garage first could be useful. Good luck (there’s always the AA)
PS I will try and access a new black plastic cap tool if possible
If you cannot get the metal cap off, use a flat blade screwdriver to prise the edge of the cap downward. Work your way around the perimeter of the cap a little at a time, it should come off.
I had this problem & in the end I drilled a tiny pilot hole in the centre of the cap & screwed a self tapper in to then grab it with a pair of needle nose pliers.
The cap sits inside the sparesafe so is inaccessibleView attachment 140167
The cap sits inside the recess against the shoulder of the bolt head , a screw driver forced at an angle , with downward pressure will apply friction to the edge where it meets the shoulder and by working around the perimeter will work it loose.
I will try this as well
I think the longer term solution will be to drill and tap in a screw.
Club shop unable to source any spare parts - just the whole bolt kit
Thanks everyone for your excellent advice
I'm going down the @Viktorgeorge route , change the metal cap for a rubber end cap & Chuck the broken puller
It has worked perfectly for me for more than two years. I have removed the sparesafe several times - including the occasional clean up and black Hammerite of the sparesafe to beat the rust - and the red rubber end cap once returned stays in place and blocks any dust etc. but is easy to see and remove.
I recently tried to take off my sparesafe to check the bolts and found taking the silver cap off the bolt virtually impossible. Resulted in my spitting the plastic cap remover tool. on closer inspection the cap is too big to fit in the plastic tool. ?anyone else had this issue and any tips on how to get the silver cap off would be good - just picturing removing this on a dark rainy night. Thanks View attachment 140160
I removed my Spare Safe completely. I had grounded it going round and up a steep slope in Cornwall. Luckily I found this out at home, as I hade to file/grind the scrape off, othwise the tool would not fit. Removing the spare is hard enough without the Spare Safe.
Not sure from the picture if sparesafe is the same as this one I got. It has a keyed head like the wheel bolts.
https:///product/campervan-parts/wh...beach-campervan-alloy-wheels-zgb-701-071-592/
