Where to spray Holts EGR Cleaner on 180 engine?
CaliGem
CaliGem
Cheshire
T5.1 se 180
I'm aware it may only be a temp fix (see other thread), but we have some EGR Cleaner. Where on earth do we spray it on these 180 engines where the EGR valve/cooler is at the front?
You have to remove the egr valve and clean the internal areas loosening the tar black residue with the spray you have bought, it is a very dirty job and you will be black for weeks afterwards
Oh, I thought you just spray it into the air tube and it makes the van run rough on idle for a second each spray?
AI Overview
To effectively use an EGR (Exhaust Gas Recirculation) cleaner spray, you need to apply it to the air intake manifold while the engine is running at idle. Disconnecting the air intake hose, often after the air filter, allows direct access to the intake manifold for spraying. Short bursts of spray, with engine recovery time in between, help prevent engine knocking and ensure the cleaner effectively reaches the targeted areas.
Here's a more detailed breakdown:
  1. Warm up the engine: Start the engine and allow it to reach operating temperature.
  2. Locate the air intake: Identify the air intake hose, typically after the air filter and before the intake manifold.
  3. Disconnect the hose: Carefully disconnect the air intake hose to expose the intake manifold.
  4. Start the engine (if not already running): Ensure the engine is running at idle speed.
  5. Spray in short bursts: Shake the EGR cleaner can and spray short bursts (about 1 second each) into the intake manifold.
  6. Monitor engine response: Observe the engine's reaction, particularly the RPM. Allow the engine to stabilize after each spray.
  7. Occasional RPM increase: Briefly increase the engine RPM to 1000-1500 between sprays to help distribute the cleaner.
  8. Stop if RPM drops: If the engine doesn't recover or the RPM drops significantly during spraying, stop the procedure.
  9. Continue until the can is empty: Use the entire contents of the EGR cleaner can.
  10. Idle and drive: Let the engine idle for 5 minutes after spraying, then drive the vehicle for a short distance (5-10 km) without exceeding 3000 RPM.
  11. Final idle and shutdown: Allow the engine to idle for at least one minute before turning it off.
  12. Reconnect the hose: Reattach the air intake hose.
  13. Clear any codes: If the engine throws any codes, use a code reader to clear them.
Important notes:
  • Always refer to the specific instructions on your EGR cleaner product.
  • Be cautious when working around the engine, as some parts may be hot.
  • Wear appropriate safety gear, such as gloves and eye protection.
  • If you are unsure about any step, consult a qualified mechanic.
I got that far, but don't know which part to remove to spray in :D
And if it works after the spray has gone through the engine combustion process may I sell you the Eiffel tower?
Or worse you are going to dislodge all that black sludge and it is going to go through the combustion process.....if it doesn't damage the engine then why do we have air filters
But isn't that exactly what happens when the EGR valve allows a % of the exhaust gasses to flow back to the inlet manifold?
When the dreaded EGR valves were playing up on a Land Rover Discovery 3 we had, I was horrified to see the state of the inlet manifold at and beyond the point where the EGR pipes were connected. The connection is well after the air cleaner on that engine. I could be wrong, but I can't imagine any EGR equipped engine to have the EGR dump upstream of the air filter. Wouldn't the filter get clogged up very quickly even with a correctly working EGR valve?.
I had a diesel smart car which needed regular decoking around the EGR Valve every 20-30K miles, when its clean it is recirculating hot gas back into the air intake into the manifold and combustion process, as it clogs up the fuel consumption goes up and your power goes down. The EGR valve on the smart is after the Air filter, the turbo, the intercooler and just prior to the manifold. The hoses between the intercooler and the manifold usually clogged up as well, so it was a two day job to clean the system, much like (for the older motorcyclists) decoking a two stroke engine exhaust system. Spraying a mist of whatever in at the air filter is purely a placebo effect unless you are doing a long time before the EGR valve shows any sign of needing it.
The benefits of a petrol Smart Car. No such worries.
So assuming a warning light for EGR already on the dash, what would you do?
Take it to a Garage and have it cleaned and inspected, and possibly replaced
All EGR Valves Coke Up, Diesel does it quicker, But Petrol engines still recirculate Gas in the exhaust taken from before the Catalytic Converter so the carbon is still present. At about 70K a petrol EGR Valve will need a strip down and clean, 660CC petrol smarts need a lower engine rebuild at 60K so there are bigger headaches
CaliGem
BristolCali
D
darrenjane
D
D
21K
mrcheesbrough
mrcheesbrough
SusiBus
SusiBus
