Daylight Running Lights DLR on only when switch is set to AUTO
Roger Boeken
Roger Boeken
calisutra
Belgium
T6.1 Ocean 204 4 motion
New customizations possible with latest version of CARISTA(rev9) .
With setting in title you can turn ignition on at night without Daylight Running Lights on.All you have to do is set light switch to 0. Before this customization DRL were always on when ignition on and inconvenient when on campsite and wanted to raise/lower roof or change heating mode late at night.
I tested it and indeed works on T6.1 ocean 2022.
I never really understood why the Scandies sensibly add rear DRLs when we only have front.
I assume that an MOT test requires the DRL’s to be on if the ignition is on and the headlight switch is in the off position although if you have auto lights I guess a tester will not bother to switch to the off position.
Yes, you are right. IF a MOT tester was to check the DRL and notice the changed behavior (DRL not on when ignition is on) than this could result in a failed test. I don't know how it's organized in the UK, but the Dutch MOT (called APK) is done mostly in the same garage as where the regular maintenance is done. I guess you'll be able to "explain" the changed behavior to the tester. Having lived in Switzerland in the past, I would not change the settings of a Swiss California, because the Swiss "MOT" is very, very strickt and done exclusively in a cantonal (governmental) testing center, with no room "to play"...:)
They don’t. Most cars in scandinavia have/use DLR like the rest of us. In Scandinavia, people have driven with their lights on during the day for as long as I can remember (that's at least 50 years). DRL didn't exist back then, so both front and rear lights were on. I can't find a reliable source stating whether DRL is a sufficient replacement for mandatory driving with lights on. But since it's customary to drive with both front and rear lights on, you now have the option of using the DLR Scandinavian way. I use this option, by the way. I agree it makes more sense than the EU regulation.
I will just have to remember to switch it back on when going for MOT.
Will correct it back temporarily when going for MOT
Thank you all for the input, I bought an OBDeleven and it was really simple to change a few settings , like DLRL's off when dial is in position zero , DLRL off when handbrake is on . I will remember to change back when going for MOT.
