EGR fault on 2010 180 BiTDI, options?
CaliGem
CaliGem
Cheshire
T5.1 se 180
Our cali has an amber warning on the dash which when plugged into a reader suggests a EGR fault. The more I read up on this, particularly with the 180 engine (50k miles), the more concerned I am.
The van does long journey's for holidays, but mostly short journey's which I know isn't ideal, but it is a 'daily driver'. It does feel sluggish on pickup, and needs a few more revs to stop it stalling on hills.
What are the options? We have bought some Holts EGR & Carb Cleaner; is that even worth trying and if so, where abouts do we spray it?
Alternatively, does it require a replacement and would an alternative make from Pierburg or Starline be a consideration as they are significantly cheaper (not sure if it includes the value and cooler for the price!). I'm told that labour is a lot because unlike other engines, many front components need removing to gain access.
Anything else we can do? We don't want to 'delete'. Have VW ever recognised as a fault that is covered under a recall and a way of checking?
(unfortunately the label in the engine has mostly perished but doesn't appear to have an A, B or D reference after the part code)
There was a problem with some 2010/11 engines but it was not related to the EGR .
I had a 2014 180 from new. The EGR had no A/B/C letter. I sold it in 2024 after 140,000 miles and it was NOT using any oil between annual services. It was a daily driver but the shortest trip was 30 miles or so.
Is your vehicle using any oil?
I would suggest carrying out an Oil Analysis on the used engine oil. If you have high levels of Aluminium then you are probably heading for increasing oil use and eventually having to replace the engine at a cost of £10,000+.
If the oil analysis is OK then you need to change the EGR valve + EGR Oil Cooler combined costing £1500+.
Cleaning the EGR valve is possible but will only be temporary.
It isn't using more oil than normal (i.e. nothing between annual services), except for a few months ago when it seemed to need a top up, but that has since stabilised.
Any idea where to spray the EGR cleaner? I can't find any videos for this particular model!
Sorry, can’t help you on that point.
Tafmet kit.... job done. Google is your friend. At 50k you may have caught it early
We want to keep the van OEM, and I believe that because of the design of the 180 engine, the Tafmet kit still requires significant labour, so we might as well just replace the valve/cooler and change our driving habits
Agree, I wanted to keep the van OEM but as the engine has a tendency to eat its own EGR cooler, I ended up relenting after trying all other measures to prevent this happening and the jury still being out on the D cooler with issues being reported.
I appreciate what you mean, but I'd assume that with a EGR valve/cooler replacement, it will at least resolve the issue for a good while, given the camper has only got to this stage over 15 years. Surely blanking it out still requires significant labour involved in ripping the whole front apart!
4 bolts (for blanking) and cable routing. One bolt is a pain though. Should be a 20min job, but took me longer.
To assist others follow the multiple threads and the solution
The whole concept of EGR is flawed, why putting exhaust gas back into the engine was ever considered a good thing is beyond me, impact on emissions is negligible. Deletion is a game changer, the performance of your van will have been affected long before any warning lights came on.
