Leaking pop tops on 2023 California Oceans
That's the annoying thing @CaliforniaCylus, it is apparently a rare thing and yet VW are washing their hands of any responsibility for it. They are not planning to investigate further and will not cover leakage under their warranty.
Leaks are primarily evident through the horizontal seam below the front fly mesh. The fly mesh acts as a reservoir and enough water tracks through to soak the front seats below.
I was thinking that it would be great to have a zip in waterproof outer for this opening for wet weather as most leaks in an 06s are at this location. I don't want a full bellows cover as we would lose all the wonderful attributes like a fully opening front or use of any of the fly mesh vents.
The vertical seams are all sealed. My 06s is dated 26/10/24 which I would assume was the date of manufacture.
I mean you could threaten the legal route as they aren't fit for purpose. Backed up with videos and photos I cannot see how they can wash their hands of it. Particularly when it's affecting seats and headlining.
You could point out there is a lot of electronic equipment waiting to be damaged...
Whilst clearly 06S aren't 100 pct fixed you could take it to Kernow transporters and the guy their will replace it for about £1100. Then take VW to the small claims court to recover the £1100.
You can print off the 180 pages of issues here and a few hundred from Germany for good measure...
Think you need to push back.
I'm assuming it's been through several wet and dry cycles as apparently there is some natural material in the cotton now which means small leaks can self seal over time.
We had 6 weeks away so a fair few wet/dry cycles in that. It leaked primarily in Germany, Freiburg (twice) and Monschau, which I thought was ironic!
Only photos, no video.
Thanks for the advice. I had read this earlier in the thread but always worth reiterating at frequent intervals.
Just wondering, has there been any reports of T7's with leaking bellows?
Perhaps not surprisingly (given the bellows T7 solution is no different to the T6.1) maybe we are starting to see first examples of water ingress
I find the response of close the roof in anything except a shower incredible. I can’t see any court in the UK finding that to be acceptable, when the vehicles are clearly advertised as “sleeps 4 people”. Soon or later someone will take this to court I hope. Maybe the advert should be amended, “sleeps 4 people when dry or only showering, sleeps only 2 when raining”.
My t6 bellows just leaked in during storm floris in the langdale valley. They've also been aquatexed so that stuff is useless too. Sideways rain storm force winds, though still kept roof up. It was wicking through the canvas mainly . No seams leaking
Do you have the old style bellows? Guess you do if you have a T6 - is this right?
Yes. 02s I believe. A big concern now for cali owners wanting to renew bellows. What do you do?
I understood the old style did not have so many leaks...perhaps they are better, but not in all situations? I also thought that T6.1 California owners had some peace of mind as the warranty would help if the leaking roof was a concern to them...maybe not?
Correct , normally dry. But in storm force conditions I get leaks. Driving sideways rain for hours and they start to show ingress. I aquatexed them for that reason after reading here it's good stuff, it isn't, it's sh1te
As stated in the Handbook.
Changed to 2024 9cean 4motion in )une - hardly used by first owner, roof leaked on first use in moderately heavy rain. Contacted Rhiannon at VW who advised needed to be checked by dealer. Did not leak under VW protocol BUT dealer advised should be replaced due to faulty stitching and daylight visible through holes. no pushback from VW and job now done. Vehicle was april 2024 build with untaped vertical seams, and replacement 6s version with taped seams. So it seams replacements still posssible. My test was two minutes of very gentle sprinkler hose, so the vw method must be pretty mild. Dealer was very careful to note that bellows are splashproof not waterproof.
