2 new leisure batteries, but volts still dropping quickly
D
daveinbracknell
Bracknell, Berkshire
T7 California Ocean 4 Motion
Hi,
Rookie query.
My recently purchased 2013 T5 SE came with new leisure batteries. Seat and wardrobe.
I have had the van on EHU for longer than two days. Display shows 100%. Also, they are being charged from the engine.
But they are not holding volts. When either the fridge or parking heater are turned on, the volts very quickly (minutes) drops to 10v then shuts down either appliance.
If I didn't know any better I'd say that new batteries are needed. Buy they are dated 2023 and clearly new.
Any ideas on what to test?
Hi,
Rookie query.
Ignore the % Display. That is a very iffy calculation. Voltage is accurate. What is the voltage after charging and 12/24hrs later with nothing switched On. Also what is the current drawn?
Also check the 75amp cube fuse on the +tve pole of the rear/wardrobe leisure battery.
Where is the best place to measure the current? I'm assuming the wardrobe battery as this is easily accessible.
I'll check this this weekend.
I'm fitting two solar panels so everything will be out for this. Thanks for your support.
I find small clamp meter like :
https://www.owon.com.hk/products_cm2100_series_smart_ac|dc__clamp_meter
very usefull. CM2100B with Bluetooth allows reading and logging on your smartphone.
Contactless measurement on minus cable either battery will give you some insight about charging/discharging leisure batteries under different load/charge conditions.
example : closing and opening electric sliding door .
30 sec to close, 30 sec to open. Short peak value of 14A. In this example I assume both batteries deliver same current . I will measure with 2 clamp meters later .
Clamp meter. Brilliant idea . Something is clearly loading the batteries excessively. Time to do some digging.
While a DC clamp meter is a useful device don't overlook post 4 which solves your problem for free.
Two 100w panels from Solar Camper Solutions now fitted and working. Very simple installation.
On the Leisure system all the circuits are connected to the underseat battery. The rear battery is just wired in parallel with the front battery. If the Solar +tve is wired BELOW the cube fuse on the rear battery then the Control Panel voltage will mimic the Solar output voltage as long as the cube fuse is OK. If the cube fuse blows, and they seem to be fragile, then the 2 voltage readings, Solar and Control panel, no longer mimic each other and you get an early warning.
I had same issue, all went away when I changed the main car / engine battery
Ohh boy, i have to ask. I feel a bit dumb doing so, in Holland we say:"there are no dumb questions" So here i go...
Is there only 1 fuse (the one in the rear) for both leisure batteries?
I have also recently changed the old batteries and i wonder if they are working properly. I checked the fuse on the back battery and it looked good. The difference in preformance between the old and the new is not that big. So i looked for the fuse on the front battery and i could not locate it...
Give me some wood and i can make you a chair or a table, but this complex clever Cali build is not my cup of coffee.
Thanks,
Tycho
Thanks,
Tycho
There is only the 1 Cube fuse, on the rear battery. Don’t depend on a visual check you really need a multimeter.
