SanderR72
		EcoFlow 220w bifacial foldable solar panel (gen2)
	For aspiring Cadac owners there's some voucher stacking discounts to be had with some models at the moment.
BBQ World (I'd never heard of them before today) have a sale on. I'd had my eye on the "2 cook 3 pro" as an upgrade to the trusty Campingaz Chef for a while. They have the Cadac at £90, with a 10% discount code bringing it down to £81.
Go Outdoors does price match +10%, making for a very affordable £72 at the till:
Cadac Cadac 2 Cook 3 Pro Deluxe QR | GO Outdoors
£150.00 | The 2 Cook 3 Pro Deluxe barbecue is your ultimate cooking...www.gooutdoors.co.uk
What wattage on 12v cigarette lighter? More or less than 100?Bought a cello 19” TV.
£129 on Amazon.
Works really well.
All apps logged in and updated.
Runs plex through my GliNet Spitz Ax3000 router to a mini Starlink.
Nice![]()
Loving this - thanks for posting the link.We paired it with one of the newer Campingaz dual regulators which also has quick release function:
Campingaz Twin Connection with Gas Pressure Regulator for Campingaz Gas Stoves, Twin Connection for EasyClic Gas Cartridges CV 300 & CV 470 Plus as well as Gas Bottles R904 & R907 https://amzn.eu/d/5I6rqGY
It’s in the EF Delta 2, USB C and pulls around 35wWhat wattage on 12v cigarette lighter? More or less than 100?
So the 19 inch TV only pulls 35 watts? On USB-C? They usually come with a 12 ciggie lighter plug also, which should be as if not more efficient - any chance you might try and report back please?It’s in the EF Delta 2, USB C and pulls around 35w
Sorry thought you meant Starlink mini.So the 19 inch TV only pulls 35 watts? On USB-C? They usually come with a 12 ciggie lighter plug also, which should be as if not more efficient - any chance you might try and report back please?
Starlink mini is around 35 w plugged into 240v
And with TV plugged into the 240v on EF delta2, it’s pulling 35 watts too.
The TV doesn’t have the 12v option.
	Ah man, I’ll need to buy another cable!Ouch, switch to 12v for the mini. Averaging 22 watts and I’m doing big downloads for work so it’s maxed out with a 50-100mbps stream for many hours now.![]()
Where can I get one from ?
Or can I use this ?
I’m going to need the 5m of cable to run it in the new vehicle
This is what I used. I already had a stepup converter from my previous Starlink:Ah man, I’ll need to buy another cable!
Or can I use this ?
That's a smart idea... annoys me trying to keep cables coiled in that unusable cupholder so retractable cables would be ideal.Charger for under the seat (seat slides back and forward with in place)
LISEN Retractable Car Charger... https://www.amazon.co.uk/dp/B0D4215HCX?ref=ppx_pop_mob_ap_share
	Looks perfect! Would you be able share a link please?Almost perfectly fitting carpet/mat for the boot. After ages wanting something to stop the floor scratching found this in Dunelm, a barrier mat which is about 94 x 80cm, rubber backed too so it doesn’t slip about - £25
Maypole 500 lumen LED magnetic work lamp and power bank from Amazon. It’s not quite soft mood lighting but will find its uses!
